My rear Diff paint is pealing. A few of you guys have mentioned re-painting them. What high temp paint are you using, and how are the results? What steps should be taken when re-painting to insure that it will not peal off again?
I used regular black spray paint. I used a wire wheel to strip the old crap off and to get the rust off, and sprayed over with plain spray paint. It's been on there for over 4 months and no peeling. It doesn't peel from the heat so much as from poor prepping. The heat just contributes to the cause by heating the dirt and oils between the paint and diff cover and since the paint isnt on good it just lifts away.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
I'm thinking of using Bill Hirsch's Miracle paint on my diff cover. That will take care of the rust permanently, but I'm not too sure of it's heat resistance. Does anyone know how hot the diff cover actually gets? I have just sent a question to Hirsch Automotive to inquire about the heat range. IIRC, past threads have mentioned temps of about 185.
Mine has some discoloration, I thought maybe I was developing rust but it's just some staining from when I had the fluid changed. Anyways, I picked up some Rustoleum Specialty High Heat spraypaint, says on the can "resists heat up to 1200 degrees". That's the ticket! I'm going to clean mine up and hit it with this stuff.
2004 Crew Cab LE 4WD
Deep Water Blue, Graphite/Titanium
Born 02/16/04
Big Tow, Off Road, Bed Extender, Floor Mats, Splashguards, Bed Mat,
OEM Hood Protector, Putco Stainless Steel Bed Rails
I used Derusto..gloss black standard oil base paint....and it has been on for a month.and is like new..I want to see if it burns off..rather than use high temp. paint and not know if it is getting too hot..so far so good..but no tows yet.
