Old 11-24-2004, 10:53 AM   #1 (permalink)
Titano24's's Avatar
Send a message via AIM to Titano24's
Well guys, let the issues begin......
I've had my titan for ~2 mths. now and I am having my first issues with it. I read all the Differential thread and decided to go change my fluid with my first oil change today @ 3500 miles.
Well I went to a local performance shop and mentioned to the service rep that I wanted to see the rear end fluid before it got dumped. To my and the techs surprise we didn't have to get that far. Once the drain plug was pulled we were shocked. It looks as teeth of the spider gears have been sheered off . I called nissan and set up an appointment this friday to get this looked at. This shouldn't happen with a truck with 3500 miles on it dammit.
Also it seems that my drivers side rear leaf spring is focked, the truck has a slight lean to the drivers side ~1.5" lower. I think this may be the same issue people are having with there "drivers side seat leaning" IT MAY BE THE DAMN TRUCK!!! Go park on level ground and put a level on your tailgate.
I would post pictures of the metal bits that came outta the rear end but my wife has my camera on a cruise. Just giving yall guys a heads up on my issues and I will update it more when nissan tells me something.....
-Shane
2004 CC 4x2 Titan LE (White)
Engine : AEM Brute Force, Airraid TBS, TB Coolent bypass, Deleted Resenators, Banks Monster Exhaust
Looks : 22" Giovanna Aburzzo's, 20% Tint, Painted Armada Front Lip, Truxedo Lo-Pro Bed Cover, 2" Rear drop, In-channel Vent Visors, OEM bugshield
Entertainment : Kenwood DDX-7015, JL Audio 1000/1, JL Audio 450/4, JL XR 6.5 Components, 2 x JL Audio 8"w7's, Audiocontrol 6XS, Kinetik 2000 and 800 batteries, *coming soon Iraggi 220amp alternator*
Titano24's is offline   Reply With Quote
Old 11-24-2004, 11:39 AM   #2 (permalink)
antwon412's Avatar
your wifes on a cruise without you? let the parties begin =)
oh yeah, and the part about the truck sucks.
SOLD! - Looking to get new LE CC LB eventually.....
2004 LE CC 4X4
Smoke/Graphite Nav Dvd Big Tow
Everything else they offer
MB Motoring Razor 20x9 / Nitto Terra Grapplers 305/55-20
FlowMaster 40 Deltas Dual Side out 3" Slant rolled tip
Westin Chrome Bull Bar
PRG 2/1 Mini Lift
2 Rockford Fosgate Power HX2 DVC 10" Subwoofers (blown now d@mnit)
1 Rockford Fosgate Power 1001BD 1000 watt Amplifier
Playstation 2 & Xbox under rear seat
"Small Victories, but victories none the less"
antwon412 is offline   Reply With Quote
Old 11-24-2004, 11:41 AM   #3 (permalink)
Titano24's's Avatar
hahahahaha
Old 11-24-2004, 11:58 AM   #4 (permalink)
cardesigner's Avatar
Just curious about your user name- do you have 24" wheels on your truck? If so, I'm wondering if that's putting an additional load on your truck and causing some problems. Just a thought.
cardesigner is offline   Reply With Quote
Old 11-24-2004, 12:08 PM   #5 (permalink)
QWIKWHIP's Avatar
I sure hope not. I highly doubt that will have any effect on it. If the truck can tow 9000lbs I doubt 24" wheels will harm it.
Old 11-24-2004, 12:09 PM   #6 (permalink)
Titano24's's Avatar
Nope, no 24's yet, still stock.
Old 11-24-2004, 12:44 PM   #7 (permalink)
Slurppie's Avatar
Send a message via AIM to Slurppie Send a message via MSN to Slurppie
I assume you had allot of debris on the drain plug magnet?
Sold 9/14/07
Slurppie is offline   Reply With Quote
Old 11-24-2004, 01:58 PM   #8 (permalink)
Titano24's's Avatar
loads of fine metal, and a few chunks of spider gears hehe
-Shane
Old 11-24-2004, 03:47 PM   #9 (permalink)
-Shane
Does it makes any noise ?. With a few chunks of spider gears broken off, I would think it'll makes lots of awful noise, does it?.
SeaRider is offline   Reply With Quote
Old 11-24-2004, 03:55 PM   #10 (permalink)
Titano24's's Avatar
No noise that I can hear, I do know that the rear end oil was burnt to all hell and back. But we shall see when nissan pulls the rear end and tells me whats up. I've had gear trouble before on other cars but that was mainly just a slight grinding. I just might not beable to hear it. Dunno, I'll keep you guys updated no doubt.
-Shane
Old 11-25-2004, 10:51 AM   #11 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
Dino gear oil is very dark and smelly, it probably was not "burnt". It's just probably inadequate to protect it, note that Nissan has started recommending 75w140.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 11-25-2004, 12:31 PM   #12 (permalink)
Titano24's's Avatar
Na the oil was burnt, I work in the petroleum industry and trust me when I say it was burnt. I have no idea why this would have happened but I also have no idea why I would have 1" long chunks of metal floating around the differential.
-Shane
Old 11-25-2004, 02:16 PM   #13 (permalink)
There are a few type of fluids which has a burning smell (ATF+4 from Mopar and diff fluid with friction modifier added) but it's totally normal, I'm not saying that this's your case but it's kinda strange when you said "few chunks of spider gears floating around" and it does not makes any noise, if you have ONE piece of metal that came off from spider gears, I don't think your be able to drive your truck to your dealer without locking up rear diff.. Let us know what Nissan dealer has found, I'm really interesting on this.
Old 11-25-2004, 02:24 PM   #14 (permalink)
Titano24's's Avatar
Will do should be going tomorrow.
-Shane
Old 11-25-2004, 03:58 PM   #15 (permalink)
-Shane
It is easy to tell when ATF is burnt, because it changes colors.
It is impossible to tell if motor or gear oil is burnt. Black color does not indicate used up oil. Only oxidation analysis can say as to whether the oil is burnt or not.
Floor Mats
Mud Guards
