Old 11-28-2004, 12:59 PM   #1 (permalink)
using 4x4 in the rain?
It was raining the road was slick everytime i came to a stop i was spinning my back wheels. I threw the truck in 4wd mode it was not slipping anymore. Am I damaging the 4x4 using it on the wet road i feel safer in the 4x4 mode.
nicochip69 is offline   Reply With Quote
Old 11-28-2004, 01:11 PM   #2 (permalink)
vw1972bugs's Avatar
not really, dont take to many turns in 4x4 on pavement and keep the speed low (-50mph)
Titan LE King Cab, 4x4
Big Tow, Galaxy Black
Pre-Runner Greg's Lift Kit
Volant Cold Air Intake (2nd Gen)
Westin Bullbar
2 PIAA 525 Fog/Driving Lights
5.6L DOHC V8 Hood Graphics
Tinted Front Windows 25%
Lund Smoke Bug Guard
vw1972bugs is offline   Reply With Quote
Old 11-28-2004, 01:26 PM   #3 (permalink)
Send a message via AIM to Batman229
dont jump on the gas and your tires wont spin
Batman229 is offline   Reply With Quote
Old 11-28-2004, 01:31 PM   #4 (permalink)
i didn't jump on the gas it kept spinning out until i threw into 4wd drive and i got great traction. I just dont want to damage the 4wd system
Old 11-28-2004, 01:40 PM   #5 (permalink)
As long as you keep the steering dead on it isn't a problem. Do not go around corners on pavement with 4x4 engaged. Go easier on the gas. In general in my truck (albeit a Chevy and not a Titan, but then, they're all equally crappy in rain), I can keep traction during 95% of wet starts. The last time I went out for a drive in the rain, the only time I lost traction out back was when I was starting from a red light uphill. My automatic locker takes care of that for me, but I still try to go easy.
The only real solution is to go easier on it.
Again, do not use 4x4 on pavement, wet or not.
Ape0r is offline   Reply With Quote
Old 11-28-2004, 01:46 PM   #6 (permalink)
Banned
Part time 4WD shouldn't be used on DRY pavement. It's fine for any surface that is somewhat slippery...including wet pavement. I've used 4WD in the rain for 20 years for just the reason mentioned....traction from a stop. Your owners manual as well as anyone driving 4X4s for a long time will tell you the same.
Now dry pavement use can wear out the tires and put undo stress on the entire 4WD system but, the tires being the parts with the most give, will be the parts that suffer most.
OnebadSE is offline   Reply With Quote
Old 11-28-2004, 04:38 PM   #7 (permalink)
If you guys are seriously spinning your tires when you're not trying to, then it would seem to me that there is something seriously wrong with your truck. Not once in my life has this happened to me. But then again, I don't treat every red light like a dragstrip. Now an icy road, that's another story, but a wet road?
skycruiser is offline   Reply With Quote
Old 11-28-2004, 05:30 PM   #8 (permalink)
If your telling US that you cant take off from a stop,without spinning your wheels, Then YOU MUST RUSH TO YOUR DEALER TOMORROW!!!!!! DONT DRIVE ANY MORE THAN YOU HAVE TO!!!!!!!!!THE PROBLEM IS ONE OF TWO THINGS!!!!!!!! 1. YOUR FRONT BRAKES ARE LOCKED-UP!!!!!(withall of the brake problems, thats possible) or 2. YOUR TRUCK HAS WAY TO MUCH POWER FOR YOU TO HANDLE!!!(only known fix is to trade it!!!!!) G.M.A.F.BREAK,And dont forget to take it out of 4wd when you do go to the DEALER!!!!!!!!!
drags1998 is offline   Reply With Quote
Old 11-28-2004, 05:54 PM   #9 (permalink)
Banned
That's pretty funny and I would have to agree. If you cannot control the gas good enough that you are spinning that frequently, then you have some serious driving issues or your truck is like none that I have ever driven in my lifetime.
vatrpr is offline   Reply With Quote
Old 11-28-2004, 06:16 PM   #10 (permalink)
LMAO@drags1998 #2. Yeah. I wanted to say it too.
Old 11-28-2004, 06:19 PM   #11 (permalink)
Shouldn't the ABLS kick in to stop the spinning tire? Don't all Titans have ABLS?
I was driving today in lightly snow covered roads with out any problems, I slid slightly making a turn from dead stop in 2wd, but it would have been alot worse in my old truck.
Greg
'04 SE king Cab -- Smoke
Off Road
Big tow
Utility Bed
Rockford Fosgate
gstlouis is offline   Reply With Quote
Old 11-28-2004, 06:31 PM   #12 (permalink)
Banned
The ABLS does seem to help the problem for the Titan, and no, not all Titans have it. Other trucks, my Frontier 4X4 SC for instance, needed to be thrown into 4WD in the rain if either pulling out of a side road briskly or from a light....sometimes.
If you've NEVER had your rear wheels spin in a light-arsed pick-up in the rain while quickly pulling out of a side road, or pulling away from a light on a hill, you're OLD!....lol
I'm sure he didn't mean ALL THE TIME, but in some situations where you need to pull out rather quickly for safety reasons, in the wet, your wheels can spin, slowing you way down. A quick switch to 4WD takes care of this.
I do have to say I haven't had this problem so far in the Titan, probably because it's much heavier but, I still throw it in anyhow at times to be sure.
Old 11-28-2004, 07:25 PM   #13 (permalink)
Yo may want to check your tires, it is not normal to spin the wheels when not trying, but in the other hand, "Better to be safe than sorry" so throw it in 4x4 until you find what is wrong, who knows maybe the rain brought the oil to the surface and made the conditions difficult for you... hope everything is ok with your truck.
Good luck.
XE CC Deep water.
cali-titan is offline   Reply With Quote
Old 11-28-2004, 07:32 PM   #14 (permalink)
Finnattic's Avatar
skycruiser
Member Number: 5928
Posts: 8 If you guys are seriously spinning your tires when you're not trying to, then it would seem to me that there is something seriously wrong with your truck. Not once in my life has this happened to me. But then again, I don't treat every red light like a dragstrip. Now an icy road, that's another story, but a wet road?
skycruiser
View Public Profile
Send a private message to skycruiser
Find More Posts by skycruiser
Add skycruiser to Your Buddy List
My Car
Car Make: 2004 SE CC 4x4
Model: none
Today, 09:00 PM #8
drags1998
Member Number: 4668
Posts: 127 If your telling US that you cant take off from a stop,without spinning your wheels, Then YOU MUST RUSH TO YOUR DEALER TOMORROW!!!!!! DONT DRIVE ANY MORE THAN YOU HAVE TO!!!!!!!!!THE PROBLEM IS ONE OF TWO THINGS!!!!!!!! 1. YOUR FRONT BRAKES ARE LOCKED-UP!!!!!(withall of the brake problems, thats possible) or 2. YOUR TRUCK HAS WAY TO MUCH POWER FOR YOU TO HANDLE!!!(only known fix is to trade it!!!!!) G.M.A.F.BREAK,And dont forget to take it out of 4wd when you do go to the DEALER!!!!!!!!!
quote skycruiser
"If you guys are seriously spinning your tires when you're not trying to, then it would seem to me that there is something seriously wrong with your truck. Not once in my life has this happened to me. But then again, I don't treat every red light like a dragstrip. Now an icy road, that's another story, but a wet road"?
With over 400 foot pounds torque dyno proven I spin when I'm not even trying on dry pavement let alone in the rain especially without true limited slip. For me the ABLS doesn't satisfy. It doesn't matter, say if your distracted and you look up to see the light has changed green, tap the gas and bark the tires...I did it in front of two cops at the light not even meaning too. Lucked out and they drove off.
I'm saying in the rain with out true limited slip it spins too much for me...
On dry pavement sure, it's not like I spin out every time by accident. Just once in a while...
Originally Posted by Finnattic
It took graduation from the "School Of Hard Knocks" (Marine Corps), with an associates in "Combat Vet" from Fallujia University to open the door to my dream job.
"Some people live an entire lifetime and wonder if they have ever made a difference to the world, but the Marines don't have that problem..." President Ronald Reagan
"There are only two kinds of people who understand Marines: Marines and the enemy. Everyone else has a second-hand opinion."
If you can read, thank a teacher. If you can read in english, thank a Marine.
By The Grace Of GOD, Guardian Angels Protect Us In Battle
2004 TiTan King Cab 4x4 SE Silver
Big Tow, Off Road Package, Utility Package
Rockford Fosgate
Volant CAI W/ Air Scoop
Borla/Gibson Hybrid Dual Exhaust
Putco Liquid Grill
Cordura Seat Covers
Husky Floor Liners
MB Gunner 6 Gloss Black 20's
Yokohama Parada Spec-X 275/55R/20
275.86 rwhp
341.59 rwtq
1/8 In 9.498 @ 72.06
1/4 In 14.934 @ 90.53
2 Degree Advance
New dyno and track times since new mods to come...
Finnattic is offline   Reply With Quote
Old 11-28-2004, 07:59 PM   #15 (permalink)
Get better tires and you will see a world of difference... for my TOYO Open Country tires work awsome in the RAIN, also mud, sand, dry pavement, highway, anything...
