Old 11-28-2004, 02:21 PM   #1 (permalink)
Send a message via AIM to Batman229
Leaf SPring lift
Just wondering if those one inch lift blocks for your leaf springs would ruin anything on the truck? Would I need a longer shock, or dont even bother with them? I got the 2"level kit and now wanted to lift the back alittle.
Batman229 is offline   Reply With Quote
Old 11-28-2004, 03:59 PM   #2 (permalink)
Lift blocks increase axle wrap due to the moment arm created by the lift block itself.
Ape0r is offline   Reply With Quote
Old 11-28-2004, 05:14 PM   #3 (permalink)
dont get it?
Old 11-28-2004, 06:08 PM   #4 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
You can put use blocks, but the biggest issue is that the rear shocks have about 8" of travel. A stock Titan sits with about 3" of droop (extension) using a block will decrease that amount by the thickness of the block. No droop, especially on the rear end, equates to a really rough ride. You can increase the length of the shock, but you will also want to increase the distance of the bumpstop by the proper amount, to keep the shock from bottoming out. You can always weld new shock mounts on too.
As for axle wrap, look at the way the leaf springs mount to the axle, they sit on top of the axle tube. The axle wants to rotate forward, under the leaves on acceleration. Putting blocks under the rear will increase the leverage that the axle can rotate, or twist, the leaves. Is it a problem? It can be, although people have used blocks for years (even alot of stock 4x's) without many side effects. Hope that helped clear things up a bit.
Old 11-28-2004, 09:25 PM   #5 (permalink)
DStewart's Avatar
Why couldn't you have a longer shackle made instead? Or go with a overload spring?
SOLD:2004 Nissan Titan 4x4-Smoke, Big tow, SE bed package, Popular package w/ captains chairs.Mods: updated aluminum rear diff cover, K&N drop-in filter, PRG lift, Firestone air bag kit, 17x9 Eagle Alloy 101's, 295/70R17 Nitto Terra Grappler, polished Billet grille-upper 3 piece and lower.
2005-FS2600 Weekend Warrior toy hauler
05 Honda CBR 600RR Black/Gunmetal w/Tribal Flames
DStewart is offline   Reply With Quote
Old 11-28-2004, 10:14 PM   #6 (permalink)
Would a 1"block ruin my ride or shock?
