Old 11-30-2004, 10:47 AM   #1 (permalink)
1st Service
Hello,
I'm coming up on 3K miles and called the dealer to inquire about scheduling my first service. Given the info that I received, I have a few questions:
1) The service rep said that Nissan's recommended service interval is 3700 miles, not 3000. Is this true?
2) I asked how long the service would take (expecting a half day to full day in the shop). He replied 30 to 45 minutes.
3) Given this, I asked what they did in that timeframe. He responded that they changed the oil and checked the other fluid levels. I asked if they drained and changed the lube in the transfer case. He said that they just checked the levels. Can this be true?
Given the previous posts here, I was under the impression that a lot more comprehensive inspection was done. Your comments are welcome. Depending on what I hear I may be calling the service manager.
Thanks!
Sprockit
SE KC 4x4
Born 8/12/04
Off Road & Big Tow
Sprockit is offline   Reply With Quote
Old 11-30-2004, 10:53 AM   #2 (permalink)
Bama334's Avatar
Just about all dealers are in competion (somewhat)with Jiffy Lube type places. My local dealer is pretty fast with just an oil changes also. Should be good to go!
2004 Titan LE CC 4X4 Offroad Blizzard
PRG Performance Package
PRG Rear Shackles- PRG Sway Bar End links
True Trac
315 BFG's on factory 17" OR Wheels
Bama334 is offline   Reply With Quote
Old 11-30-2004, 12:06 PM   #3 (permalink)
Pugsly's Avatar
this is an oil change and not a service check up right?
i doubt they will check the rear diff. and fill it if need be.
by fluids i beleive he means, washer, coolant, and visual inspect the master cylander level. other than that you have to ask him to check (which also might mean additional charge beyond the usual "oil change" fee.
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
Pugsly is offline   Reply With Quote
Old 11-30-2004, 12:32 PM   #4 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
Thanks!
[sarcasm] You can believe everything you read on the Internet....[/sarcasm]
Seriously though, I just checked against the service manual, which I have installed on my computer here, and the only service listed at the 3750 mile initial service is to change the oil and filter. This is following Schedule I, by the way, the severe service schedule.
There is also a Premium Maintenance schedule listed in the owner's manual for the maintenance obcessed.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 11-30-2004, 03:35 PM   #5 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
I waited until atleast 3750 to do an oil change (I think it actually turned out to be right at 4k), and won't be doing the synthetic switch until 10k. Just whatever you do, since I saw someone mention Jiffy Lube, don't go there. For an oil change I personally would stick with the dealer, since Jiffy Lube either won't do the service or if they do, they will ALWAYS find something (so they say) that supposedly needs to be replaced. I constantly had guys at Jiffy Lube telling me I needed service, no matter how many times I told them I just had it done by the dealer.
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
TomTom One 125 GPS
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
Old 11-30-2004, 06:40 PM   #6 (permalink)
rockwalltitan's Avatar
Keith, you are absolutely correct. I had to tell the guys at jiffy lube that they had not put the drain plug back after they began filling it. I have also had the cap left off. Do it yourself or take it to the dealer.
2004 SMOKE CREW CAB LE
OFF ROAD, BIG TOW, NISSAN BED EXTENDER, NISSAN BED RAILS, NISSAN EXECUTIVE PLASTIC COIN TRAY (not included), TINT, BORN ON 2-19-2004
rockwalltitan is offline   Reply With Quote
Old 11-30-2004, 06:54 PM   #7 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Engine oil and differential oils are easy enough to do yourself...and you can sleep knowing it is done correct.....I also like to change my spark plugs and # them.they tell a story.....and I cut oil filters open too!!
honeykeeper is offline   Reply With Quote
