Old 12-03-2004, 09:17 PM   #1 (permalink)
Tire pressure warning light!!!
I came out of work tonight, started the truck, and my tire pressure light came on. I thought I might have a flat. Got out and checked and everything looked fine. Stopped at the gas station, put a little air in the two front tires, but the light is still on.
It is pretty cold here in Pittsburgh tonight (high 20's right now).
What tire pressure are you "cold weather guys" running???
How can I get this damn light to go off??
'04 Black LE 4x4 Crew Cab, Big Tow, Volant CAI, Flowmaster 50 series dual exhaust, Tekstyle low-pro tonneau cover, 20 inch chrome Eagle Alloy wheels, Mr. Grille billet grille, Xm Sat radio, Nissan all weather floor mats, Armada front bumper air dam (painted black).....Truck is gone!! Traded for 2006 Maxima in 5/06.....Titan's RULE!...(gas prices were killin' me)
PENROSE is offline   Reply With Quote
Old 12-03-2004, 09:28 PM   #2 (permalink)
pluckyew's Avatar
np, just need some air, 28psi+
check tire pressures...
inflate to above 28psi, say about 35psi, cold air.
then drive for few minuits, the light will turn off.
np.
trivial fact: that sensor is about $70 per wheel, if you were to replace it for some reason.
Twenty Aught Four Titan KC 4x4 SE, Smoke: Off-Road/Big-Tow/Utility/Bench 6-seater.
"The state that separates its scholars from its warriors will have its thinking done by cowards, and its fighting by fools," Thucydides.
pluckyew is offline   Reply With Quote
Old 12-03-2004, 09:33 PM   #3 (permalink)
Also, if you do pump them up when its real cold out, it can't hurt to check them if you get a warm afternoon. I put mine to 40 front/37 rear a few weeks ago, and yesterday I got ready to head home from school for the weekend, it was pretty sunny and warm. The tires were close to 50, over their max of 44 from the sidewall. Needless to say I drained them back down to 40 before I left.
Ape0r is offline   Reply With Quote
Old 12-03-2004, 09:42 PM   #4 (permalink)
mikegronholz's Avatar
Umm ... the sidewall markings are for max pressure cold ... i.e. not being driven on, after sitting for a while. the air will heat and expand as you drive. The tire was designed for this. I believe it even mentions it on the tire ... MAX xxPSI COLD. If you drained your tire down to 40PSI after driving on it for awhile, your tires are now underinflated. You air them down and hook up and try to tow that 9000# the Titan can, you seriously risk a blowout !!! Read ALL the directions, then apply what you read. ALso, BTW, higher air pressure generally get you better mileage ... just a side note
2008.5 Nissan Titan SE CC 4x4
RF with Buckets
Black Grill
Chrome Mirrors and Handles
Medium Tow Package (everything but gears)
Line-X with Ducks Unlimited Logo
15% Tint All The Way Around
Llumar Paint Protection
20" Enkei TSP1's
305/55-20 Toyo OC AT
Bilstein Adjustable 5100 Fronts at 1"
Bilstein 5100 Rears
Magnaflow Duals
Garmin Nuvi 660
Cobra 75-WS XT
3' Firestik
Serving as a Tow Rig for my Jeep Cherokee ...
mikegronholz is offline   Reply With Quote
Old 12-04-2004, 04:30 AM   #5 (permalink)
JAH
Mid-20s here in central Virginia...
35 PSI front and rear.
JAH
2004 Titan SE CC 4x4 Radiant Silver
Offroad Package
Airbag Package
Utili-track
Popular Package
JAH is offline   Reply With Quote
Old 12-04-2004, 04:41 AM   #6 (permalink)
werdivers2's Avatar
The temp here in Colorado Springs has been 2-40 lately. My light has been on for a few weeks. I have checked the pressure a couple of times and each tire reads 36psi. I haven't taken it in, or called the dealership so not sure exactly what the problem is.
*Side note: I am starting to get a vibration when I use the brakes at only 4,000 miles.
Shawacky
werdivers2 is offline   Reply With Quote
Old 12-04-2004, 06:04 AM   #7 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
I am putting air in my tirres twice a week...I think the seals are leaking for the sensors....anyone else check their air twice a week to top up?????
honeykeeper is offline   Reply With Quote
Old 12-04-2004, 06:47 AM   #8 (permalink)
beano's Avatar
Penrose I'm from Pittsburgh also,running 35psi no problems.Galaxy Black is awesome!
beano is offline   Reply With Quote
Old 12-04-2004, 07:25 AM   #9 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
I think most of you are measuring your PSI after you have driven home from work or been out running an errand. Hopefully not, but be sure to check w/o even starting your vehicle. I had the sensor go off when the temperature fell to the low 30's here in Central Illinois and once I got the PSI up to 40 warm (I don't have a compressor at home and had to go somewhere to air them up) and drove it for awhile, the alarm turned off.
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 12-04-2004, 07:28 AM   #10 (permalink)
I'd love to just disable the warning light. I wonder if the dealer can do this. Mine goes on and off at random... makes them useless... like the boy who cried wolf.
rfrench102 is offline   Reply With Quote
Old 12-04-2004, 07:32 AM   #11 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
If the temp drops, it's gonna set off the warning light. Mine did this when we first got down to 40 about a month ago...was on a for a few days, but when I checked the tires when it went off, they were 25-30psi, but within a few days it was back up to normal, plus it went into the dealer for an oil change within a week (but the light had turned off by then) and they should have checked the pressure and topped them off if necessary. It's already been down below freezing here and the light hasn't gone off again (knock on wood).
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
Old 12-04-2004, 11:48 AM   #12 (permalink)
Hey, what's up? I am really from Connellsville (about 30 minutes south of the 'Burgh). I just say that I am from Pittsburgh because who the hell ever heard of Connellsville??
As far as Galaxy black being awesome..........ehhh.....
I wash mine constantly to keep it clean. Nothing looks better than a CLEAN black vehicle. But it is so hard to keep it that way. I have some minor scrathes on mine already (1000 miles) and they really stand out on the black paint. When you look at it one way it looks great, but if the sun hits it a certain way,and you look at it at a certain angle.....you see all the dust, water marks, swirls.....etc.....DINGS! (thankfully I don't have any of those...YET!)
STEELERS!!!!!!!!!!!!! I am a Steeler FREAK!! I have tickets to the Steelers/Jets game. Can't wait.
Old 12-04-2004, 11:52 AM   #13 (permalink)
That's why I drained them to 40 BEFORE I left, like I said above, lol. Truck hadn't been driven in over 24 hours at that point!
Old 12-04-2004, 01:40 PM   #14 (permalink)
My light came on the other day, checked my tires they were all at 30psi cold. Aired back up to 36 light went off.
XE KC 4x4 Offroad (traded for 06 DodgeRam 2500 CTD 4x4)
My own Big Tow
Prodigy Brake Controller
Sirius Sat Radio
CB
Born on 3/26/04
04 Xterra,Airaid intake
aztitan4x4 is offline   Reply With Quote
Old 12-04-2004, 05:57 PM   #15 (permalink)
It would be nice if there was a way the warning light
could let you know which tire is causing the light to
illuminate. Something like the 4-wheel drive icon
and it would blink the low tire(s).
Nr1 Qualifier
2004 LE KC 4x4
Nr1 Qualifier is offline   Reply With Quote
