Old 12-04-2004, 12:05 AM   #1 (permalink)
Popping Noise When Turning
Anyone experience a popping noise from the front right when turning at slow speeds? It's like 3-4 popping noises as I turn the truck. It's only at low speeds, and it happens more when there is a variance in grade. For the life of me can't figure out what might be causing it.
JWILLS is offline   Reply With Quote
Old 12-04-2004, 12:28 AM   #2 (permalink)
TITANAK's Avatar
front end noise
Ya, i can hear a noise in the front when i am turning and spin my rear wheels in 2wd. I took a friend for a ride to listen and he thought it could be the ABS pumps... or not
2005 Red Brawn KC LE
K&N FIPK Series 77
325/65/18 MT 18x9 Ultra Stargazers
Pro Comp 6" lift
Traction Bars
Donahoe coilovers
Bilstiens
Leafspring helpers
Dan Moore custom grill inserts
Banks Monster exhaust
TITANAK is offline   Reply With Quote
Old 12-04-2004, 06:47 AM   #3 (permalink)
RED BRAWN SE CC's Avatar
Check your skid plates, mine was loose and making noises.
Titan CC SE 4x2 - Red Brawn
OEM Fogs
OEM Step Rails
K&N Drop In
BFG AT 285-65-18
Rhino spray in bedliner
Mobil 1 5-30
Mobil 1 75-140
RED BRAWN SE CC is offline   Reply With Quote
Old 12-04-2004, 08:06 PM   #4 (permalink)
Mine pops at the beginning of a right turn. Just enough to feel it in the steering wheel.
04 Red Brawn KC SE SOLD!!!!!!!
01 Lightning # 1916
391hp/500tq
braun04 is offline   Reply With Quote
Old 12-04-2004, 08:56 PM   #5 (permalink)
pciley's Avatar
That doesn't sound healthy. Get your head under there with the wheel all the way turned and see if you spot something that could bind. With the truck jacked up, you won't find it because the suspension won't be compressed. I'd hate to think something is bent from a pot hole or something like that and is now interfering. See what the dealer says.
Has it always done this since you bought the truck, or did it just start happening?
My Astro van does that turning to the right but it is a piece of junk work truck and I don't care to put any money into it. When the wheels fall off, I'll get another one .. might not be too long from now.
KC XE Smoke
Old 12-04-2004, 08:58 PM   #6 (permalink)
Rack and Pinion?
SE Popular
18" Rims
Galaxy
Big Tow
offerings12 is offline   Reply With Quote
Old 12-04-2004, 09:00 PM   #7 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Check your ball joints..may be a bad one.
honeykeeper is offline   Reply With Quote
Old 12-04-2004, 09:00 PM   #8 (permalink)
pciley's Avatar
The steering travel should be set so the pinion can't hit the last tooth on the rack... "should be" being the key words... lol. Maybe a tech can check that too.
Was thinking more like tie rods... are they still called that? been a while.
J Wills, do you have 4x or 2x?
KC XE Smoke
Old 12-04-2004, 10:14 PM   #9 (permalink)
titanwild's Avatar
Yep, I've got the same thing, kind of a pop/scrunch type of noise, only does it one time, not repeated. Seems to occur when the right-side suspension is unloaded a bit (right-hand turn) and when going over a small bump (same as grade change, I guess).
I thought it might be the Jet Tech helper springs on the rear leafs, but am convinced that it's coming from the front end somewhere.
First one with a fix wins my vote for 'hero of the month'!!
TitanWild
DeepWater 4x2 KingCab SE,
Big Tow, RF Pop, and Bed Packages, 29Mar04 MDate, Custom Flo-Pro Crossflow Dual Exhaust,
JetTech Traction bars, K&N drop In, OEM Fogs, XD5 9005/9006 Xenon bulbs, Viper 350 Alarm.
titanwild is offline   Reply With Quote
Old 12-05-2004, 05:42 AM   #10 (permalink)
check the ball joints man!!!
Old 12-05-2004, 11:34 AM   #11 (permalink)
titanwild's Avatar
OK, OK, It's off to the dealer next week!! Let you know what happens.
Thanks.
TitanWild
Old 12-05-2004, 10:54 PM   #12 (permalink)
Thanks for all the responses....Pciley, I have a 4X4 CC. Checked the skid plates, and they are secure. Just eye-balling the front end with an untrained eye nothing was obviously bent, broken, or bleeding. I'm gonna give the ball joints a closer look as Tom suggested, but it looks like a trip to the dealer. Another reason to hassle them again about putting one of the '05 diff covers on.
Old 12-06-2004, 05:05 AM   #13 (permalink)
Good luck on the cover deal....as you can see that item only has gone to 05 buyers?????? Not sure why they are making people crazy over it!! Let me know about the ball joints!! Good luck.
Old 01-22-2005, 02:15 PM   #14 (permalink)
Just to close the loop on this one....Deal says it's a bad rack and pinion causing the popping noise. More specifically the rack is bad. Will be replacing as a warranty fix.
JWILLS
Old 01-22-2005, 02:28 PM   #15 (permalink)
Thumbs up Tie rod ends bad here on right
JWILLS
My dealer checked mine too......bad tie-rod joints on right......but it pops on the left????? We'll see after they are replaced next week.
Peace-Tom
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac.
In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
