the factory built in option is the exact same as the dealer installed way your dealer syas he can do. Basicly they add a Nissan Specific xm tuner under the dash(same spot and exactly mounted the same way as the factory). they both than soley use the head unit and steering wheel controls. the main differance your dealer is saying is that the factory version uses the extremely large glass mount antenna. It sounds as if your dealer is hinting to use a terk micro roof mount antenna (which is the way to go)
so in short the dealer installed option is the exact same as the factory option. (ps you can easily do it your self and save the install costs)
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
