Old 12-10-2004, 02:47 PM   #1 (permalink)
veejay's Avatar
HELP! Looking for tachometer signal...
hooking up remote start. having a hard time locating tach signal using service manual
anyone who has installed remote start before can you help me? prefer to use the tach signal going to ecm, but whatever is easier! thanks
04 Titan King Cab XE 4x2
06 Husqvarna SM450R
00 Ducati 748
99 Husqvarna CR125
03 German Shepherd
04 American Pit Bull Terrier
veejay is offline   Reply With Quote
Old 12-10-2004, 03:23 PM   #2 (permalink)
TIsTAN's Avatar
my installer tapped the harness near the battery in the engine bay.
directed lists the following,
item - Tachometer
wire color - NOT white/blue or black
polarity - ac
wire location - any ignition coil
TIsTAN is offline   Reply With Quote
Old 12-10-2004, 04:12 PM   #3 (permalink)
veejay's Avatar
my alarm/remote start is nonDEI (Prestige) and is looking for a negative (-) coil input. Is this the same for DEI? Is it also looking for - input?
I see the black, white/blue, yellow/red lines to the coils. black is obviously ground... so which one do I use?!
Thanks for the help
06 Husqvarna SM450R
00 Ducati 748
99 Husqvarna CR125
03 German Shepherd
Old 12-10-2004, 07:41 PM   #4 (permalink)
TIsTAN's Avatar
i have a clifford intellistart and according to the installation manual..."connect this wire to the vehicle coil's negative side or the noncommon fuel injector wire." i think it's the same system as yours, so following directed's notes, it's not the black wire nor the white/blue wire.
if you need, go to www.directed.com and look up the intellistart manual.
Old 12-10-2004, 08:59 PM   #5 (permalink)
1BadTitan's Avatar
The tach wire is at any coil pack under the hood...There are 3 wires, one is white w/blue stripe and another is black. They are common on every coil pack. The 3rd wire is the odd colored one. That is the wire you want to tap into. I've been doing these things for about 10 years
TACH REFERENCE.....NOT WHT w/BLU or BLACK..... AT ANY IGNITION COIL
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
Old 12-10-2004, 11:25 PM   #6 (permalink)
veejay's Avatar
thanks for the help... i will try tomorrow.
the instructions also lists an option for multi coil systems, but requires an adapter. I will try it off a single coil first and hope it works!
06 Husqvarna SM450R
00 Ducati 748
99 Husqvarna CR125
03 German Shepherd
Old 12-11-2004, 05:16 PM   #7 (permalink)
veejay's Avatar
no luck...
tach signal is apprx. .16 vac, and rises with rpms.
is this the normal voltage for tach signal? trying to avoid having to use a multi coil pack adaptor which I can't even find!
suggestions?
06 Husqvarna SM450R
00 Ducati 748
99 Husqvarna CR125
03 German Shepherd
Old 12-12-2004, 09:22 AM   #8 (permalink)
TIsTAN's Avatar
clifford manual says a dmm will read 1v-6v AC and fluctuate with rpm. multi coil ignition systems regsiter lower amounts of AC voltage.
Old 12-12-2004, 09:32 AM   #9 (permalink)
Supporting Vendor (Gold)
Tach Signal:
(AC)
This vehicle has independent coils, there are three wires per coil, White/Blue, Black and the third is the tach signal wire. Or you can use the pposite of White on the injectors
Headunit: Kenwood Execlon DDX812
Front Stage Amp: Mmats SQ2175
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 12-12-2004, 09:15 PM   #10 (permalink)
1BadTitan's Avatar
I just told him that, he said no workie... Do the tachless setup if you cant find a signal.
1BadTitan
Old 12-13-2004, 01:14 PM   #11 (permalink)
veejay's Avatar
k thanks for the help fellas... everything works now, using a single coil for the reference.
turns out the on/off disable switch for the remote start had a bad connection. One of the wires wasn't soldered on the back of the switch too well!
06 Husqvarna SM450R
00 Ducati 748
99 Husqvarna CR125
03 German Shepherd
Old 12-13-2004, 03:51 PM   #12 (permalink)
Glad you here that!!
a select few."
