Old 12-11-2004, 04:21 PM   #1 (permalink)
20TITAN04's Avatar
Rims
Just wanted some opinions on these rims . Also if they fit , and what kind of ride i should expect ? Thanks...
http://www.discountedwheelwarehouse....ShowLarge=True
20TITAN04 is offline   Reply With Quote
Old 12-11-2004, 05:26 PM   #2 (permalink)
gr8titan's Avatar
Originally Posted by 20TITAN04
Just wanted some opinions on these rims . Also if the fit , and what kind of ride i should expect ? Thanks...
The ride you get depends upon the type of tire you mount on these 20 inch rims. I have 20x9 rims and Nitto Terra Grappler 305/50R-20 and I get "excellent" ride similar to OEM. The best improvement I noticed is the lateral handling with the OEM suspension. If you mount taller tires with more aggressive treads, and a lifted suspension, OR slam the truck and use 40 series tires or lower, then the quality of ride is compromised. By the way, NICE rims!! PEACE
gr8titan is offline   Reply With Quote
Old 12-14-2004, 12:47 PM   #3 (permalink)
Hello,
I have a 2005 LE 4x2 Crew on order and I will be removing the stock wheels immediately. Do your 305's stick out beyond the wheel well lip?
Thx in advance,
Tony
pennsytitan is offline   Reply With Quote
Old 12-14-2004, 02:00 PM   #4 (permalink)
gr8titan's Avatar
Originally Posted by pennsytitan
Hello,
Thx in advance,
Tony
I do not know if there is a major clearance difference between a 4x2 and a 4x4.... I am using a 20x9 rims which is a tad wider than the common 20x8.5 in. My 305/50R20's are just at the edge of the wheel lip and this is the exact "look" I am looking for. With my OEM suspended 4x4, the tires do not hit my wheel well lip even if I hit a large bump. My research indicates that this is the "optimum wheel/tire combination" without altering height and fender clearances. Check my link below my SIG for some photos. PEACE
