Old 12-12-2004, 10:10 AM   #1 (permalink)
QShip's Avatar
Oil filter on Titan not coming off!!!
Any suggestions on how to remove a stubborn oil filter? The filter is pretty banged up after my futile efforts.
It simply has not budged. I've already drained the oil and I'm not sure if the filter has a hole in it.
Thanks in advance!
QShip is offline   Reply With Quote
Old 12-12-2004, 10:12 AM   #2 (permalink)
got_titan's Avatar
a big pair of channel locks usually works for me
Old 12-12-2004, 10:14 AM   #3 (permalink)
QShip's Avatar
Thank you got_titan!! I'll give that a shot!
Old 12-12-2004, 10:35 AM   #4 (permalink)
SUBTITAN's Avatar
If that doesn't work try a large screw driver through the filter, the only problem with this option is that your truck is parked until you change it.
2004 Titan CC 4X2 LE Canteen
"SUB out going sinker"
SUBTITAN is offline   Reply With Quote
Old 12-12-2004, 10:36 AM   #5 (permalink)
There have been earlier posts about the oil filter being screwed down WAY too tight at the factory. Mine was. I used a strap wrench. You could also use a chain type wrench. If worse comes to worse, stick a large screwdriver through it.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 12-12-2004, 10:43 AM   #6 (permalink)
Not a good trend, dealer had to cut ours off!
We took our Titan in for its first oil change. After 1 1/2 hrs. the service guy says sorry about the delay, but we had to cut the filter off. This sure sounds like over tightening to me.
2manycarz is offline   Reply With Quote
Old 12-12-2004, 11:18 AM   #7 (permalink)
mjw357's Avatar
yes, some major over-tightening here. there is no need to tighten to the point of having to use tools to remove if the seal is in place and clean, I always tighten and remove by hand. In fact, over-tightening can cause a leak by distorting the seal.
Old 12-12-2004, 11:28 AM   #8 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
I use one of those black tools that fit over the end of the filter. You can get them at Walmart. They are indexed by Fram part numbers, but work fine to get off the OEM filter. The OEM filter was on mine a bit tight, but with the tool and the breaker bar it was loose with one firm tug. Look for one that is compatible with PH7317, which is the Fram part number for the Titan.
Note: do NOT use the tool to tighen the filter, tighten it by hand. Also don't use Fram filters, they are the suck!
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 12-12-2004, 11:30 AM   #9 (permalink)
If the filter is banged up, you shouldn't drive it anyways as there is a good possibility that you have collapsed the inner metal tube that holds the filter media from collapsing inwards.
Floor Mats
Mud Guards
Old 12-12-2004, 11:31 AM   #10 (permalink)
CaliforniaTitan's Avatar
LOL I just went through this yesterday on the first change of the '05. I ended up having to usea screwdriver punched through it myself to get it off...my cap type filter wrench just kept slipping and not turning anything.
Chris
Old 12-12-2004, 11:36 AM   #11 (permalink)
http://www.lislecorp.com/tool_detail.cfm?detail=1051 This works great for small filters like the titans. the tighter the filter, the harder it clamps. I have never had A filter that it would not take off, and I use it every day.
S.RayRay is offline   Reply With Quote
Old 12-12-2004, 12:32 PM   #12 (permalink)
Mine too was a PITA! The problem is the limited space you have to get good solid leverage. I used a metal strap wrench and after some time, I was able to get it off. I made sure the new one went on hand tight, then another 1/2 to 3/4 turn as always. Next one will be a snap.
Pearl White 04 Titan SE CC 4X4 w/Big Tow, Utility and Off-Road pkgs with E-LOCK. Buckets w/consol shifter. Step rails, Hood bug deflector. Rear Sonar, BOD=5/04.
TitanicSE is offline   Reply With Quote
Old 12-12-2004, 12:37 PM   #13 (permalink)
I had 4 cars that I bought new, every single time the Oil Filter was so tight, that I ussually take it to the dealer, or another oil shop so I can watch and see how they do it, sometimes learning from the pros is faster, better, safer than from the manual, anyway, yes the first oil change I let the dealer do it, after that I do my own oil changes and the filter goes hand tight, as hard as I can but always by hand, no tools and never a problem.
XE CC Deep water.
cali-titan is offline   Reply With Quote
Old 12-12-2004, 02:21 PM   #14 (permalink)
vw1972bugs's Avatar
strap wench will work. The orig filter is damb tight.
Titan LE King Cab, 4x4
Big Tow, Galaxy Black
Pre-Runner Greg's Lift Kit
Volant Cold Air Intake (2nd Gen)
Westin Bullbar
2 PIAA 525 Fog/Driving Lights
5.6L DOHC V8 Hood Graphics
Tinted Front Windows 25%
Lund Smoke Bug Guard
vw1972bugs is offline   Reply With Quote
Old 12-12-2004, 02:48 PM   #15 (permalink)
Have you tried this wrench on your Titan's filter? I did and the wrench was too big.
BayouTitan
Popular Package
Utility Bed Package
Born on 12/03
