Originally Posted by bestatchess
Probably fish the wires through the hood latch release cable grommet in the driver's side firewall with a coat hanger.
You can either cut a hole in one of the existing blanks to mount an aftermarket switch directly through the blank, or else buy a factory switch to fit the opening.
Thanks. I'll take a "run" at the hood release grommet.
Regarding the "blank" switch: "cutting a hole" and "lucky" will need to go hand-in-hand
... just in case things get ugly, are there part numbers, Nissan or aftermarket, for replacement switches that will fit those openings?
I guess there aren't any solenoid placement ideas... I'll investigate the area next to the battery.
