Old 12-18-2004, 10:11 AM   #16 (permalink)
pciley's Avatar
Originally Posted by Russell
Alright does anyone know if I can order the lights and if the XE is prewirred for them. I have the popular package and I tell you what it is dark inside the cab with the one stinking light.
Unfortunately the door is not prewired for Jack Didley.
I swapped door harnesses with those from an SE and they had the little extra lead for the courtesy lights. When I plugged the lights in, nothing happened. The harness that the door harnesses plug into under the dash is not wired to control those lights. This leads me to believe that the BCM would also not know what do to if you upgraded the wiring under the dash as well. IOW, you would change a bunch of harnesses and still not have the lighting capability in your doors without having the correct BCM from an SE.
I carry a 4 D-cell Maglight in my door. Might also come in handy during a car jacking
KC XE Smoke
Old 12-25-2004, 05:50 PM   #17 (permalink)
Hey Got-Titan. I have the same, LE CC Big Tow pkg with the big mirrors on both sides. I do not have the "Puddle Lights" on the underside of the mirrors either. Dealer said they were in the doors (not). I am wonderiing if anyone has lights in the mirrors at all and if they do is it only on the small Mirrors and not for the Big Tow Mirrors.
k94max is offline   Reply With Quote
Old 12-25-2004, 09:27 PM   #18 (permalink)
The puddle lights are on the bottom of the doors. I have not seen a titan with any lights on the side mirrors?
gmdeacon is offline   Reply With Quote
Old 12-25-2004, 09:37 PM   #19 (permalink)
The LE model has the puddle light on the bottom of the sideview mirrors. They help light up the area by the door at night. Adding the BIG TOW package eliminates these lights because the larger tow mirrors don't offer them.
Pearl White 04 Titan SE CC 4X4 w/Big Tow, Utility and Off-Road pkgs with E-LOCK. Buckets w/consol shifter. Step rails, Hood bug deflector. Rear Sonar, BOD=5/04.
TitanicSE is offline   Reply With Quote
Old 12-27-2004, 08:29 PM   #20 (permalink)
Thanks TitanicSE. I thought that I had read somewhere that the Big Tow lost the puddle lights but I wasn't sure. I know I don't have them on mine so I would think that is the reason for no puddle lights.
