Old 12-18-2004, 09:09 AM   #1 (permalink)
Banned
jhromy's Avatar
another tire pressure question
On my XE Titan on the tire's it states to never exceed 40 psi, but my tires are set all at 37 psi cold and im sure it heats up past 40 while driving...is that safe??? is the warning on the tire for cold temperature or should i lower them all down to 35?
jhromy is offline   Reply With Quote
Old 12-18-2004, 10:04 AM   #2 (permalink)
pciley's Avatar
Anyone will tell you that "max weight @ 'xx' PSI" is for COLD tires.
You can safely inflate them to 40 and carry the max payload of your truck and not have problems.
If you drop to 35, that is probably OK too... with negligable losses in fuel economy and treadwear, probably too small to notice.
KC XE Smoke
Old 12-18-2004, 10:26 AM   #3 (permalink)
TYTAIN's Avatar
Yeah the pressure is for cold tires, the maufactures has done all the testing for ya, so you can air them to the max cold and be good to go!
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 12-18-2004, 10:35 AM   #4 (permalink)
Banned
jhromy's Avatar
thanks guys for clearing that up for me
Old 12-18-2004, 01:26 PM   #5 (permalink)
Kalani938's Avatar
I just checked mine today and they all had 44lbs. The tire max says 44lbs, is this okay or should I drop them a few lbs? They are the 18' Goodyear Wranglers.
04 Radiant Silver CC SE 2WD
BOD 10/5/04 purchased 10/23/04
Kalani938 is offline   Reply With Quote
Old 12-18-2004, 02:01 PM   #6 (permalink)
tnbowhunter's Avatar
It depends on if they were hot or cold. If they were cold then they are over-inflated. If hot and you let air out, when they cooled down they would probably be under-inflated.
2001 Polaris Sportsman 500.
Old 12-18-2004, 02:57 PM   #7 (permalink)
Kalani938's Avatar
When I checked them earlier, they were hot. I just checked them cold a few minutes ago and they were at 42lbs, is this too much?
Old 12-18-2004, 03:13 PM   #8 (permalink)
I like to check mine after sitting overnight, that way I can get a truly accurate reading. If you check them in the morning or after it has sit without driving for several hours and they are at 42 I would definitely air them down to 35 psi.
Old 12-19-2004, 07:54 AM   #9 (permalink)
TYTAIN's Avatar
Just remember there are three different tires on the Titan
1. 285/70517 with the OR PKG max pressure of 35PSI (I have these)
2. the 18" tires (max 44 psi)
3. the 17" tire for the XE PKG (not the same tire or size as OR PKG)
All of these have different tire pressures check you sidewall for your max cold inflation pressures then can play with your air pressures from there to suit your needed.
PRG Shackles
