How to fix a Paint Chip?
It appears something quite pointy put a ding on my bed side. I say pointy, because there is a very small indention in the sheet metal, like where a point hit, but the area is very small, not like a door ding. Almost looks like a BB gun. After cleaning off all the loose disturbed paint, left a spot about 3/8" in diameter where the paint is popped off clean. For temporary protection, I globbed in touch up paint with the brush applicator. However, surface is obviously not smooth. Color matches, the radiant silver hides it well. How can I get a smooth finish? Is the spray touch up available yet. On white vehicles, I've spot sprayed, then blended with 1000 grit. Will that work with the metalflake and clear coat?
