Old 12-21-2004, 04:01 PM   #1 (permalink)
Question Oil use too high?
My 2004 Titan seems to have used about a half quart of oil in about 1500 miles. This seems to be excessive to me? The truck has 4500mi on it and 1500mi since changing to Mobile 1 0w-40. The driving is mostly stop and go; (short trips 10mi or less) with light loads (sub 1000 lbs). I am not seeing any blue smoke at start-up as others have indicated... Any ideas?; and does this seem like a problem for the dealer or is it normal... Note: everything else seems fine! Thanks.
jeff7777 is offline   Reply With Quote
Old 12-21-2004, 04:06 PM   #2 (permalink)
IMADOGMAN's Avatar
Jeff, Are you certain that it is using it? I filled mine with the recommended amount of oil, and it only came up between the Low and High marks on the dipstick. When I changed it, it was at the full mark, but after I ran it for a few minutes, and then let it sit for a while, it was only at the midpoint. Make a note of where it is now, and check it again in a 1000 miles or so.
PS Mine never moves from this midpoint. I don't think it has used any oil in 8000+ miles.
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 12-21-2004, 04:34 PM   #3 (permalink)
I did fill it up using exactly the amount listed in the manual, but the oil filter is a Pure 1 which is slightly larger than stock, so that may be the issue... I will fill it up to the mark and keep an eye on it... Thanks.
Old 12-21-2004, 05:08 PM   #4 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Mine used about 1/2 qt. before first change.I believe at break-in time it is quite NORMAL to use more than after break-in time......I'm sure you are fine....just don't let them put 5 qts. of oil in at change time.....now enjoy!!
honeykeeper is offline   Reply With Quote
Old 12-21-2004, 05:15 PM   #5 (permalink)
titanwild's Avatar
DogMan right
Originally Posted by IMADOGMAN
filled with the recommended amount of oil, and it only came up between the Low and High marks on the dipstick. When I changed it, it was at the full mark, but after I ran it for a few minutes, and then let it sit for a while, it was only at the midpoint.
Exactly my experience. 6.5 qts with Nissan filter is midway between high low on dipstick, hasn't changed in nearly 5000 miles since the M1 0W-40 change.
Welcome to the forum and good luck!
TitanWild
DeepWater 4x2 KingCab SE,
Big Tow, RF Pop, and Bed Packages, 29Mar04 MDate, Custom Flo-Pro Crossflow Dual Exhaust,
JetTech Traction bars, K&N drop In, OEM Fogs, XD5 9005/9006 Xenon bulbs, Viper 350 Alarm.
titanwild is offline   Reply With Quote
Old 12-21-2004, 06:05 PM   #6 (permalink)
Well.the dipstick is the reference anyway....some things never change.lol!
Old 12-21-2004, 07:03 PM   #7 (permalink)
raskm's Avatar
HEHE......I hope so...
Manual said 6 1/2 qts and I had to put in 7 to get to full mark...this is common from others also. when you changed oil how many qts did you put in?
2004 NISSAN TITAN SE CC*4X4*OR/BT*OEM BUG DEFLECTOR*IN-CHANNEL VENTSHADE VENT VISORS (absolute junk!!)*SMOKERS PACKAGE*CATCH ALL FLOOR MATS*NISSAN SEAT COVERS*
raskm is offline   Reply With Quote
Old 12-21-2004, 08:44 PM   #8 (permalink)
smoothTitan's Avatar
6 1/2 quarts here. right in the middle of the two lines where the manual says it should be. if im not mistaking, if you fill all the way to the top line then you got to much, but prob not to much to worry about.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 12-21-2004, 09:15 PM   #9 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
Originally Posted by Truck41
you will never know the exact oil usage, because all the oil never drains back. if you can measure the amount of oil that's left in the top end, then you have something concrete. that is why there is a anti-drainback valve, so the engine will get oil sooner.
The anti-drainback "valve" (really it's just a piece of silicon rubber) is in the oil filter, not the top end of the engine. And the filter is the first thing in the oil circuit, so as the bearings get lubed first and get clean oil.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 12-22-2004, 04:55 AM   #10 (permalink)
I always fill to the top line....in hopes it will be better lubrication for steep inclines I travel on in the mountains daily. No problems ever with the higher mark used on my last truck either.
Old 12-22-2004, 07:35 AM   #11 (permalink)
rarjar's Avatar
Agree Tom- filling to the top line (about 7 quarts) is my practice. The additional 1/2 quart, according to my mechanic brother-in-law, will not create an overfill problem.
2004 Titan 4x4 Pearl White LE King Cab
Tekonsha Voyager Trailer Brake Controller
OEM Bed Divider
Superior leaf spring helpers
Lund X-terminator bug shield
Graphite/Titanium leather seats
Born-on date 6/10/04
Purchased 6/19/04
"We're all here because we're not all there!"
rarjar is offline   Reply With Quote
