just wondering the reason nissan went with 75w140on the 05's. seems pretty thick especially in 10 degree weather. 75w140 is what we use in our coal trucks which have 60000 lb rear ends.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
the oil recomended is a synthetic...which most synthetics flow great even at temps lower then 10 degs.
PRG Performance Kit w/SAW's
Born 9/2004
So, is that a synthetic? I hope so because I don't want to have to change my fluid when my truck finally arrives.
The 05's should come with synthetic 75-140w, you will be ready to go, and as a bone-a$$ you just might get a finned aluminum rear end cover
Born 9/2004
Anybody with a '04' put 75w-140 gear oil in yet? I know it is in the '05's. Is the finned diff. cover the only difference between the '04' and '05'? Should we be using the '05' gear oil?
Keep in mind that the first number is the "winter" number. 75w-140 and 75w-90 both maintain the same kinematic viscosity of 75 weight gear lube in cold weather. The 140 rating is the gear lube's kinematic viscosity at high temperatures.
I'll be putting 75w-140 in my Titan after I finish breaking it in. I'm going to use Amsoil gear lube and oil when the time comes.
I have an appointment tonight to get my rear diff. changed. It only has 1600 miles on it and it should have the 75W140 in it. I will try and take some pictures of the oil that comes out and post them tonight.
AKA GoCougsKev
2005 Silver Titan LE CC 4WD
Born on 11/04
Adopted 11/04
Navigation System, DVD, Sunroof, Big Tow, Off Road, Side/Curtain Airbags
A.R.E Z Series Canopy
E&G Classic Billet Grill
OEM Bug Deflector
Prodigy Brake Controller
I've heard of no changes between the '04 and '05 rear diff other than the cover... so one would think the '04 should also be using 75w-140. I changed mine out to 75w-140 about 2 weeks ago and haven't had any problems. The original fluid was very dark, had a horrible burned smell, and the drain plug was covered with a thick sludge... glad I changed it!
2004 Nissan Titan Crew Cab SE - Smoke
At the dealership yesterday and some of the early 05 don't have the aluminum
diff cover.
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
The winter number is not kinematic viscosity, it's in cP (centistrokes) at a given temperature. I don't know what that temp is offhand without looking, but it is certainly within a range and varies somewhat.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
dark gear oil-normal due to ep, moly adds.
smells burnt-normal, due to ep and sulfur adds
sludge on drain plug-it was moly assembly lube on mine. Used when assembling bearings, fell down to the bottom after a few miles.
Floor Mats
Mud Guards
it is expensive but it supposed to be the best. We use it in power plant cooling towers where the gear boxes are operating on a 24 / 7 cycle.
Do you use the 203 or the 212 in your Titan?
Floor Mats
Mud Guards
