Old 12-23-2004, 03:45 PM   #16 (permalink)
I meant it to be funni.. I should have said I'm surprized that no one replied with "DO-A-SEARCH" Most of the time I learn things from simply reading the posts and not even knowing what to search for. so.. I support the threads like these
04CCinBrLa is offline   Reply With Quote
Old 12-23-2004, 04:26 PM   #17 (permalink)
Banned
Squid's Avatar
You bet, I had your back.
Squid is offline   Reply With Quote
Old 12-23-2004, 07:56 PM   #18 (permalink)
Khamburg's Avatar
They had a simialar IAT control box available for the Dodge Trucks. You could buy one for around 30 bucks and would just basically set the temp on the unit for 20 degrees less than the outside temperature to get a richer mixture. It had mixed reviews and some had problems with it tripping check engine lights on the Ram Pickups. I can't think of too many things that would increase horsepower, torque AND gas mileage.
2004 Copper LE QC 2x4, Big Tow Package
Khamburg is offline   Reply With Quote
Old 12-23-2004, 08:18 PM   #19 (permalink)
frankyD's Avatar
Most mass produced products cause a small increase in fuelling wich might be beneficial if your motor happens to be running slightly lean, but idealy this sort of thing is used to adjust for a small increase in airflow. On a side note most motorcycles run slightly rich and often make more power on the dyno when they are leaned slightly. I think this is as a safety precaution to make up for manufacturing tolerances and they can because their are no emmisions standards. On my duck I just use a power commander, much cleaner than tricking computer. also just to brag I can get 60mpg on the highway with the duck. That should get me in trouble.
frankyD is offline   Reply With Quote
