Old 12-23-2004, 01:46 PM   #1 (permalink)
smoothTitan's Avatar
rear sonar problem!
i got in my truck this morning, put it in reverse and the sonar beepeing noise was steady not the beap on then off it was solid. i got out checked if anything was behind me and nothing was there. anyways it would not go off it does it everytime i put it in reverse. i eventually had to just turn it off.
has this happened to any of you guys?
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 12-23-2004, 03:32 PM   #2 (permalink)
Since I don't know where you live, what have the weather condition's been like there overnight? Warm/Cold.... Clear/Rainy/Snowy/REALLY snowy... etc. Have you run through any big puddles in the last few days? Did you try a wet cloth across the sensors ?
I don't have the sonar system, but I'm suspecting that something is blocking at least one of the sensors and/or at least one of the connectors for the sensors has some junk in it... wether it be water/salt/sand/slush residue, etc....
JAOHN is offline   Reply With Quote
Old 12-23-2004, 03:40 PM   #3 (permalink)
i wiped the sensors off, and it quit for a few minutes then it started again. its about 20 degrees here with a little sleet.
Trenz billet
15% tint
Old 12-23-2004, 06:32 PM   #4 (permalink)
pyromedic's Avatar
It may have some ice build up on the sensors. I'd just turn it off untill it warms up a little.
LE CC Titan / Silver 05'
Big Tow/Navi
Born on 10-09-04
number 1301
pyromedic is offline   Reply With Quote
Old 12-23-2004, 08:08 PM   #5 (permalink)
I've had that happen on the wifes Quest. It was a small wet leaf on one of the sensors. You probably had some dirt or a bit of ice on it. If not, have the dealer check it.
Pearl White 04 Titan SE CC 4X4 w/Big Tow, Utility and Off-Road pkgs with E-LOCK. Buckets w/consol shifter. Step rails, Hood bug deflector. Rear Sonar, BOD=5/04.
TitanicSE is offline   Reply With Quote
Old 12-23-2004, 09:10 PM   #6 (permalink)
Pugsly's Avatar
check to see that one of the sensors wasn't pushed into the bumper slightly. it must be flush or it'll sense the bumper as an object and beep.
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
Pugsly is offline   Reply With Quote
Old 12-23-2004, 10:53 PM   #7 (permalink)
ill check it
Trenz billet
15% tint
Old 12-24-2004, 06:41 AM   #8 (permalink)
http://www.infinitihelp.com/Ownershi.../NTB04-102.htm
There is a TSB on this if you haven't check it yet.
04CCinBrLa is offline   Reply With Quote
Old 12-24-2004, 10:27 AM   #9 (permalink)
Haz-Matt's Avatar
That TSB is for the 2004 model, I have a 2005 and I have the same problem. once the temps droped below freezing the sonor sometimes (a few times it did not do it) would start a solid tone. I tried to locate the sensor control unit but could not find it in the place describe by the TSB. Has the control unit been moved to a new location on the 2005 Titans?
Thanks,
Matt
Haz-Matt is offline   Reply With Quote
Old 12-24-2004, 03:16 PM   #10 (permalink)
thanks guys. its really cold here so i would say the temp has something to do with it, mine is doing exactly like matt said.
Trenz billet
15% tint
Old 12-24-2004, 06:53 PM   #11 (permalink)
Bill_n's Avatar
Why yes .... as a matter of fact it has ....
Section DI of the 2005 manual shows that it is on the back cabin wall ... drivers side ... behind the back seat ...
It also tells you how to put the sonar unit into "self-diagnostics" mode ... and how to read the beep fault codes ....
Bill_n is offline   Reply With Quote
Old 01-23-2005, 02:28 PM   #12 (permalink)
Chaad32's Avatar
My '05 titan had that same sonar probolem today....for the record it was 19 degrees outside and there was some freezing rain last night. I know this sounds like a no brainer of a probolem of simply wiping off the sensors, but i swear the sensors were clean when i checked them and i wiped them off just in case and the probolem still continued. Later on that today it got to about 33 degrees and the solid beep went away. I will go to the dealership with this TSB info later. http://www.infinitihelp.com/Ownershi.../NTB04-102.htm
'05 Titan CC 4X4 LE Galaxy Black
Utilitrack W/extender and gate
AVS bug deflector
AVS ventshades
Ipod mp3
Chaad32 is offline   Reply With Quote
Old 01-23-2005, 09:37 PM   #13 (permalink)
Great.... so it's not just the back-up sensor... but it's also the 'time to wash the truck' sensor as well
mtofell is offline   Reply With Quote
Old 01-24-2005, 06:15 AM   #14 (permalink)
daschtick's Avatar
I have noticed that on cold mornings, my aftermarket sonar will pick up the steam from the exhaust, causing to beep intermittently. I am unsure if the factory system will false like this, but it is something to keep in mind.
2004 Red Brawn/Graphite
King Cab, LE, 4WD, Big Tow
Truxedo Low Profile (Utilitrac), Magnaflow 5x11 Polished Muffler
OEM XM receiver, Infinti QX56 Center Console Armrest
Born 8/24/04, Delivered 9/8/04
daschtick is offline   Reply With Quote
Old 05-15-2005, 06:56 PM   #15 (permalink)
dizguy's Avatar
Send a message via AIM to dizguy
I have an 05 with the sonar, and it doesnt work. It beeps for 3 seconds and shuts off.
05 Smoke CC LE
Navi Sys., Hitch, Chrome Hooks, L/H Beam Sylvania Lighs, K&N Air Charger, Debadged, Mobil 1, K&N O/F.
dizguy is offline   Reply With Quote
