12-26-2004, 06:37 PM
#1 (permalink )
Weird Mystery Drip...Worried
There is some fluid on my drivers front inner fender. Its in the engine bay right next to the air box. It seems to be dripping from that hose thats ziptied to the air box that goes nowhere. It just hangs there. What is it. It's clear like the brake fluid. And I just had dealer do my brake fix this past week. What is it and what is that hose.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
12-26-2004, 06:49 PM
#2 (permalink )
Is the brake fluid up to the full/max line? It might just be residual fluid from a spill. I'd go back and have them clean it up for you and do an inspection while in there. In the mean time I'd leave a bit of extra room in front when approaching a stop situation, just in case.
Clint
12-26-2004, 06:51 PM
#3 (permalink )
Hey my name's Clint too. It's not at the top but about 1/4 inch from the high level line. I'm paranoid over this.
1BadTitan
12-26-2004, 07:08 PM
#4 (permalink )
Brake fluid ruins the paint... water will disolve it, if it is break fluid you may want mention it to the dealer, the work corrosion comes to my mind.
Anyway, good luck.
XE CC Deep water.
12-26-2004, 07:16 PM
#5 (permalink )
Their problem, I just want to know what that hose is, then I can figure out whats coming out of it and why.
1BadTitan
12-26-2004, 07:20 PM
#6 (permalink )
Have someone sit in the truck while running and apply the brakes. If it's leaking you should be able to see where it's coming from.
Clint
12-26-2004, 07:23 PM
#7 (permalink )
I tried that, it didn't do anything. It may be intermitant.
1BadTitan
12-26-2004, 07:29 PM
#8 (permalink )
the hose is the breather for the front diff.
steve
steve
2nd set GoRhino® Dominator II™Nerf Bars - 2°Timing Advance
12-26-2004, 07:38 PM
#9 (permalink )
Why would it be spitting gear oil? I used the 4wd about 3 days ago. I also changed the front diff to synthetic. Could I have overfilled it? Is it just going to overflow and be ok?
1BadTitan
12-26-2004, 08:43 PM
#10 (permalink )
pretty much any time you wake up to find that you have a "mystery drip" there is cause for concern!
HS
12-26-2004, 08:58 PM
#11 (permalink )
Yes indeed
1BadTitan
12-27-2004, 05:25 AM
#12 (permalink )
Its pretty tuff to overfill a diff unless its parked on an incline when doing it. not sure what the drip is but, that is what that hose is.
steve
steve
12-27-2004, 02:00 PM
#13 (permalink )
Well I dont remember what it called for but it took about an extra 3/4 to get it to spill back out the hole.
1BadTitan
Display Modes
Rate This Thread
Linear Mode
AutoForums.com
Truck
European
Import
Domestic
Manufacturer
