Old 12-27-2004, 10:44 PM   #1 (permalink)
hunka27's Avatar
Capacitors
just wondering if anyone can give me advice on getting a good capacitor. what makes a difference besides the farad's... what is 16 volt rating 20 surge mean? thanks
2004 Titan XE, Galaxy Black, Preferred Package.
Picked it up 10/28/04
Best thing thats ever happened to me
hunka27 is offline   Reply With Quote
Old 12-27-2004, 11:24 PM   #2 (permalink)
loufish's Avatar
I can tell you this, one Fared in a lot of capacitence. Capacitors (usually measured in Micro-Fareds) are sized for the electrical job requiered of them, you design a circut that requies "X" amount of capacitence, and that's what you use.
"16 volt rating, 20 surge" sounds like a component designed to normally take 16 volts, but can survive surges up to 20 volts...
No the real question....what the heck do you think you need a capacitor for?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 12-28-2004, 10:32 PM   #3 (permalink)
hunka27's Avatar
car stereo of course...
Old 12-29-2004, 07:08 AM   #4 (permalink)
I bought two Lighning Audio 1 farad capacitors and they were both defective. The first one had the on-board voltage display and it would not hold charge and the second one, w/o voltage display, arrived with a smashed mounting bracket.
Old 12-29-2004, 07:17 AM   #5 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
DigiKey is a good order catalogue for electronic components....it is a good free catalogue to have.
honeykeeper is offline   Reply With Quote
Old 12-29-2004, 09:22 AM   #6 (permalink)
loufish's Avatar
OK....so where do I put this capacitor? In the CD slot?
Consider me audio illiterate.
Of course I know there're used in cross-overs, but is there somewere else?
Born 9/2004
2002 Honda XR650R
