Old 12-29-2004, 11:46 AM   #1 (permalink)
stick's Avatar
Location: So Cal...whats the weather like? oh yeah, sunny and warm!
correct idle rpms
do any of you out there in titan land know what the correct (read:what the factory setting/best for gas mileage is) idling rpms should be? when my truck is in park it seems to idle around 1000-1200 and when it has a load (at a stop light in drive with the brake on) it runs a little under 1000. the reason i ask is it seems like its idling a little 'hot'. so i don't know if a 'hot' idle could be a sign of something that needs to be adjusted that may also help with gas mileage. thanks
stick is offline   Reply With Quote
Old 12-29-2004, 01:00 PM   #2 (permalink)
Yes that’s high, don’t know off hand but a sticker under the hood should tell correct warm idle.
KC/LE 4x2
Galaxy Black/Titanium
No-Tow/No-Offroad
G.Banks&Trux.cover
PRG. 2.5"F 1"R.
305/55/20 Nitto's TG
20x9MB Motoring Razor's Chrome
Optimist is offline   Reply With Quote
Old 12-29-2004, 01:20 PM   #3 (permalink)
scr38's Avatar
Correct idle speed (with engine warmed up) is 650 RPM +- 50 RPM.
Old 12-29-2004, 01:30 PM   #4 (permalink)
stick's Avatar
can you adjust it yourself or is it a dealer issue? technically if nothing needs to be adjusted, how long before the idle should drop to 650-700?
Old 12-29-2004, 02:53 PM   #5 (permalink)
scr38's Avatar
Take it to the dealer; there may be other issues involved. The lenght of time it takes to drop to 650 depends on several factors - outside temp, load on engine, etc. But it should drop to the proper RPM quickly if warm; it may take 5-10 minutes if it is cold.
Old 12-29-2004, 04:56 PM   #6 (permalink)
dman's Avatar
Is this in gear or park? Seems like that would be in gear (drive).
dman is offline   Reply With Quote
Old 12-29-2004, 07:15 PM   #7 (permalink)
scr38's Avatar
In park or neutral.
Old 12-29-2004, 10:33 PM   #8 (permalink)
stick's Avatar
if it is running 'hot' does that affect gas mileage when you are driving or is it just during idle? (ie. does high idle indicate something that will affect other gas mileage issues?)
