Make sure rad cap is off first...then turn engine and heat on(Full Heat)...let get to temp and start to squeeze the upper hose gently...you should see bubbles coming out the top, do this over and over again until bubbles stop. On some vehicles you need to do this for about 20 minutes....while doing this do not let the level go down...The best way to fill the rad at the beginning is from upper hose(Distilled water only!!) My wife last winter told me the heat didn't work...When I did the flush I just filled...well there is lots of bubbles in there...looks full, but alot of bubbles in there and it will not heat very well or at all... Good luck
2004 NISSAN TITAN SE CC*4X4*OR/BT*OEM BUG DEFLECTOR*IN-CHANNEL VENTSHADE VENT VISORS (absolute junk!!)*SMOKERS PACKAGE*CATCH ALL FLOOR MATS*NISSAN SEAT COVERS*
