Old 12-30-2004, 09:48 AM   #1 (permalink)
Banned
Send a message via ICQ to Titan_TX Send a message via AIM to Titan_TX Send a message via MSN to Titan_TX
After rotor replacement now vibrations
I get vibrations now above 60 mph. I took it as far as 90 and still continue. I never had them before the rotor replacement. The steering wheel is now shaking. I am so pissed off. It seems everytime I take it in they fuc something else up.
Any ideas what this could be?
Titan_TX is offline   Reply With Quote
Old 12-30-2004, 09:52 AM   #2 (permalink)
37L1's Avatar
I'm not sure if this will solve your problem but you probably should check the torque on all your lug nuts. I wouldn't trust others to be exact about that when they removed and replaced your wheels.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 12-30-2004, 09:53 AM   #3 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
My .02 is this:
Pads were not replaced and have a warped shape to them. Need to have them replaced as well.
The other thought on this is possible a balance and rotation on your tires. When I had new rotors get put on two vehicles, I have had to get the tires rebalanced to eliminate all vibrations. Seems odd, but I did it on a grand prix and on my Maxima.
It could be something else entirely but that is my instinctive response for what your problem is. Good luck!
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 12-30-2004, 09:54 AM   #4 (permalink)
logicjunky's Avatar
Actually, the lug nut idea is probably it. I bet in balancing the tires they just didn't have the lug nut torque even on each one of the nuts and all 4 tires.
~Born 08/04~
~Adopted 09/04~
Old 12-30-2004, 11:36 AM   #5 (permalink)
dman's Avatar
This would be my guess too. When they removed your wheels they may have knocked off one of the weights. Not sure how they are attached but if they are just clamped onto the rims this could easily be your problem.
dman is offline   Reply With Quote
Old 12-30-2004, 04:50 PM   #6 (permalink)
Banned
That was it. They balanced the front tires, and the truck has never been even this smooth! It's perfect!
Old 12-30-2004, 08:07 PM   #7 (permalink)
im taking my truck in monday for the brake vibration. they act like they never herd of this, they said will turn the rotors. I asked, will u replace them? he said no, what happens if it happens again, I asked. He said we will keep turning them intill we have to replace them. What should I be prepared for. Will turning them help or should i get them replaced
1st Titan is offline   Reply With Quote
Old 12-30-2004, 08:27 PM   #8 (permalink)
I long for the day when a dealer might use some forward thinking and actually anticipate a requirement before it is identified by the consumer requiring yet another time wasting trip.
04 SMK LE/CC, 4X4, NAV, DVD, S/R, OR, BT.
Likecars is offline   Reply With Quote
Old 12-30-2004, 08:34 PM   #9 (permalink)
nmanley's Avatar
1st Titan, I talked to my service manager today about the main Titan issues I've read here. He said Nissan made the dealership buy a $8000 brake lathe just because of these problems. He also has a different brake pad that nissan has changed to to help prevent the jitters that people call warping. It's acutally bad pad material build up in the metel of the disk. turning them gets rid of the bad layer and gives the new pad a good disk to work with. Make SURE they give you the newer disk pads and if they don't want to admit to it have the let you talk to a reginal customer service rep...he'll know about it I bet!
Nolan
2004 4x2 CC LE
Black Low Profile Bed tool box, Homemade bed cover, Delphi XM Roady2, Airbox mod w/Fram Air Hog filter, Banks Monster Exhaust installed, Mobile 1 Oil and filter, 85-145 Royal Purple Synthetic Diff fluid, Garmin Zumo 550 GPS, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring Like llajumpvid did his except using two 7" monitors for front and back coverage.
nmanley is offline   Reply With Quote
Old 12-30-2004, 08:38 PM   #10 (permalink)
Thanks for the info
Old 12-31-2004, 12:11 AM   #11 (permalink)
Banned
They already gave me the new pads the first time I went in for the brakes. Just the rotors they didn't replace.
Old 12-31-2004, 12:35 AM   #12 (permalink)
dman's Avatar
I just had the brakes done last week, the pads definitely look bigger than the originals. They didn't even drive my truck to see the brake judder first hand. The dealers definitely know there is a problem.
Old 12-31-2004, 12:35 AM   #13 (permalink)
dman's Avatar
AWESOME. I'm glad it was something that simple.
Old 12-31-2004, 01:56 PM   #14 (permalink)
RockyMtnTitan's Avatar
It's truly amazing how many different stories these dealers tell us regarding this well-known brake issue. Here's my story: Taking mine in for brake tsb in 2 weeks. Service writer ordered new rotors and new pads.....both of which are supposedly a new design. I told him I was taking my truck to a different dealer unless they replaced the rotors, instead of just turning them. His response was basically that replacing the rotors and pads is the only option, because you'll just be back in another 3000 miles or so, which of course was my thought too. Made my mind up in a hurry as to which dealer will be allowed to service my Titan. Stick by your guns and insist on new rotors!
Hey TX, did the dealer mention whether or not your new rotors are a new design?? Glad the re-balancing took care of your vibration issue.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 12-31-2004, 02:32 PM   #15 (permalink)
Banned
They didn't mention about a new design. So I am not sure on that.
