Old 12-31-2004, 03:01 PM   #1 (permalink)
jdm
Dash Rattle Found
Due to road construction I have been taking a different route to work each day. The new route is much rougher and one section of road is "washboard".
I have noticed a rattle coming from my dash when driving on the washboard section of the highway. It took several days, but I found that I could place my hand on the defroster vent on the driver side and press down and the rattle would go away (until I took my hand off, or got back to smoother road).
Today I pulled the defroster vent off. There is (6) 1" high styrofoam blocks glued to the dash that the vent sits on for support on the passenger side.
There is only (1) styrofoam block on the driver side, and it is on the very end of the driver side end of the vent. The styrofoam blocks are on the edge of the vent hole next to the windshield.
I got some thick pieces of velvet tape and made me some blocks to support the vent on the driver side. RATTLE GONE!!!!!
Lazy assembly line workers!!!!!!!!!!!!!!!!!
jdm is offline   Reply With Quote
Old 12-31-2004, 03:06 PM   #2 (permalink)
garo1's Avatar
Good find. I'll have to do the same, these rattles are driving me nuts!
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 12-31-2004, 03:12 PM   #3 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
Been trying to fix this one myself I ended up using some weatherstriping around the whole piece. But the rattle has since come back. I did not recal seeing any blocks, but maybe I'll check again and get some thicker stripping.
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 12-31-2004, 03:29 PM   #4 (permalink)
dman's Avatar
Hmmm...velvet tape??? Where do you find this stuff at? My girlfriend has been complaining that the shackles and hand cuffs have been chafing her wrists and ankles. She will be real happy to hear that there is something called velvet tape
dman is offline   Reply With Quote
Old 12-31-2004, 04:08 PM   #5 (permalink)
RED BRAWN SE CC's Avatar
GENIUS!!
Titan CC SE 4x2 - Red Brawn
OEM Fogs
OEM Step Rails
K&N Drop In
BFG AT 285-65-18
Rhino spray in bedliner
Mobil 1 5-30
Mobil 1 75-140
RED BRAWN SE CC is offline   Reply With Quote
Old 12-31-2004, 04:18 PM   #6 (permalink)
scr38's Avatar
Don't be cheap! I line mine with mink!
Old 12-31-2004, 04:42 PM   #7 (permalink)
Alas, a use and an excuse to get rid of those black velvet paintings of dogs playing poker and Elvis.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 12-31-2004, 06:56 PM   #8 (permalink)
jdm
Had my mind in the gutter and got busted!!!
It actually was Felt tape from Home Depot.
Old 01-18-2005, 09:47 PM   #9 (permalink)
SarkaZm's Avatar
Originally Posted by SarkaZm
Been trying to fix this one myself I ended up using some weather striping around the whole piece. But the rattle has since come back. I did not recall seeing any blocks, but maybe I'll check again and get some thicker stripping.
Well, since I took it in to the dealer for various fixes and they said that they could not reproduce the rattle...I decided to give it another try myself. I did discover that I do have the little white foam like blocks mentioned above, but interestingly, they are all about equally spaced apart...except for around the area of the rattle! I picked up some thicker foam and placed some in the bare spot. While I had the defroster cover off I did some pushing on the defroster 'vent tube' itself and noticed a sound very much like my rattle. After some careful and high tech evaluation (more pushing) it appears as though a tab on the vent was hitting something below it. If you look through the windshield while the defroster cover is off you will see a bunch of "caulking" type stuff on the metal below the vent. This is where the tab on the vent seemed to be hitting making the noise. I ended up using some high density foam pads and cut a piece into 1/2" X 3" strip. After some careful maneuvering with a screwdriver and my now bloody fingers I was able to position the foam strip below the tab...believe me it is pretty tight. Well, after all this I hope that my rattle is gone . I will be able to tell for sure in the morning when it is colder because that is when it rattled the worst. Hopefully all this typing will help some others with this issue too. It appears that all the weatherstripping I put around the vent cover was probably needless, but I will leave it on just in case! I'll keep ya posted! Sorry for the length!
More Pic's Here
Old 01-18-2005, 10:15 PM   #10 (permalink)
loufish's Avatar
How did you get the defroster vent out? I just picked up a rattle this morning from the pass. side, sounds like something is rolling back & forth when you hit the brakes, or gas...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 01-18-2005, 10:27 PM   #11 (permalink)
SarkaZm's Avatar
I only took the cover off, I'm pretty sure you need to remove a good portion of the dash to get the actual vent tube out. I basically just pushed up/down on the plastic pieces and wedged the foam underneath. There are some small bolts (7mm) that attach the vent to the dash, you may want to try removing those and see if you can pull the vent out. That was going to be my next try if this doesn't work...but I'm confident! Just don't drop the bolts if you try it!!
More Pic's Here
Old 01-19-2005, 08:24 PM   #12 (permalink)
BigRedTitan's Avatar
Thanks for going through the "pain" from your "bloody fingers" to type this to inform us of this possible fix. I hope it was worth the sweat, tears and blood loss. Let us know.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 01-19-2005, 08:35 PM   #13 (permalink)
SarkaZm's Avatar
LoL, no problem. Actually I cut 2 fingers at my cuticle so typing is no problem This morning was good, no rattles so far! Now if I can get my seat to stop creaking!
More Pic's Here
Old 01-24-2005, 11:21 PM   #14 (permalink)
SarkaZm's Avatar
Just an update...so far so good. No more dash rattle. Here are some pictures of where I put the foam piece. Sorry it's kind of hard to see, but it's a tight spot! The yellow arrow is one of the main bolts that was loose. The gray arrows are here I put the foam (you cannot see the foam piece as it is under the plastic that is closest to the windshield). You'll need to pry between the defroster vent and the plastic. It's kind of hard to explain but if you take the vent cover off and push around on the dash and hear a sticking/popping sound...then you have the same rattle as I did.
More Pic's Here
Old 01-31-2005, 06:05 AM   #15 (permalink)
Sorry, could explain how easy is it to get the vent cover off?
talltom is offline   Reply With Quote
