Old 01-02-2005, 05:25 PM   #1 (permalink)
Unhappy Engine oil smells like gas....
It seems to at least....I am using Mobil 1 synthetic (5W-30) and only have 4,000 miles on my truck. The oil was changed roughly 1,000 miles ago. Has anyone experienced this in their Titan?
maestro is offline   Reply With Quote
Old 01-02-2005, 07:07 PM   #2 (permalink)
raskm's Avatar
How far do you drive each day? Do you let it idle for long periods of time?
2004 NISSAN TITAN SE CC*4X4*OR/BT*OEM BUG DEFLECTOR*IN-CHANNEL VENTSHADE VENT VISORS (absolute junk!!)*SMOKERS PACKAGE*CATCH ALL FLOOR MATS*NISSAN SEAT COVERS*
raskm is offline   Reply With Quote
Old 01-02-2005, 07:23 PM   #3 (permalink)
I drive roughly 40 miles a day with no unusual amount of idling. Im sure that this thing can't have such a huge problem already. It just seems that the oil is more acrid smelling than usual. Maybe its the "new car jitters" thing..
Old 01-02-2005, 07:29 PM   #4 (permalink)
raskm's Avatar
I would not worry UNLESS it was a strong gas smell. If you are worried take to dealer or get an Oil Analysis.
Old 01-02-2005, 07:30 PM   #5 (permalink)
Clint's Avatar
I personally have never used synthetic oil. Is this your first experience with it? Could it be possible that this happens to be normal? My guess is nothing is wrong, it's just the way it's suposed to be...
Clint
Old 01-02-2005, 09:13 PM   #6 (permalink)
TYTAIN's Avatar
I would do oil analysis, for your piece of mind, and proof to your dealer if it does. You know what type things happen at the stealership don't we! Hope it dosen't have fuel in the oil, but good luck!!!!!!!!!!!!
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 01-02-2005, 09:27 PM   #7 (permalink)
NorCal 4x4's Avatar
I agree with Ray the oil guy.
You might also compare the odor of the used vs. new. If different mix a drop of gas in with a small amount of the new and see if it resembles the used. [Don't sniff it too much or you might become just another strange headline in the local paper].
Old 01-03-2005, 03:00 PM   #8 (permalink)
sgbofav's Avatar
Oil smell and color are not accurate to determine an oil's ability to lubricate. Like others have said, "when in doubt, do a UOA" Used Oil Analysis.
2004 Deepwater Nissan Titan, Crew Cab(10/24/04)
AMSOIL SVG 75w-140 gear lube
AMSOIL SAE 10w-30 oil
"No arsenal, or no weapon in the arsenals of the world, is so formidable as the will and moral courage of free men and women.
- Ronald Reagan
sgbofav is offline   Reply With Quote
Old 01-03-2005, 03:10 PM   #9 (permalink)
HemiHunter's Avatar
I never thought I would actually go outside and smell my oil, but after reading your post I did. I too use Mobil 1. It has a petroleum distillate smell close to gasoline. Not sure if it's normal or not, but it's clean and my truck runs fine.
HemiHunter is offline   Reply With Quote
Old 01-03-2005, 03:32 PM   #10 (permalink)
raskm's Avatar
Some older engines can pass fuel through worn or broken rings and can actually thin the oil....This will be a strong fuel smell. Correct me if I am wrong as I can say I am an expert becuase I have only read about this problem on the Toyota boards..
Old 01-03-2005, 03:44 PM   #11 (permalink)
TOK
TOK's Avatar
If there is enough fuel getting past the rings that you smell it, is it possible there is enough in there to have it burn on the dipstick? Not highly scientific, but a lot quicker than an oil anaylisis. I wouldn't be comfortable driving a truck that I thought had diluted oil while I waited for the results.
My gut tells me everything is OK, and you're just being a little worried about problems with such a large investment. Wouldn't a ring leaking bad enough to be contaminating the oil be triggereing a misfire or lean condition and lighting the Service Engine light?
TOK is offline   Reply With Quote
Old 01-03-2005, 06:00 PM   #12 (permalink)
Banned
Squid's Avatar
Never have, and I'm not going to start.
What next taste the diff lube?
Or put your tounge on the spark plug wire to see if it's firing?
Squid is offline   Reply With Quote
