Old 01-03-2005, 04:20 PM   #1 (permalink)
TallTexan's Avatar
Found another rattle and the fix!
I have been looking for a rattle in the dash but just now hit the jack pot. Pulled the cover off the radio and the wiring harness running from the cover in the dash had no support. Both connectors was flopping against the dash. A couple of tie wraps later and no rattle. Now I have to look at the passenger side door for another one of those critters.
Robert Louis Stevenson
Old 01-03-2005, 05:05 PM   #2 (permalink)
How difficult was it to get the cover off of the radio? Any tricks to doing it without scratching the heck out of the dash? I have a rattle in the same area and can't get to it by taking the glove box out, so this might work.
Cmayer31 is offline   Reply With Quote
Old 01-03-2005, 05:20 PM   #3 (permalink)
pciley's Avatar
try a search:
How do you remove radio insert?
There are several others too with more detail
KC XE Smoke
Old 01-03-2005, 09:32 PM   #4 (permalink)
TallTexan's Avatar
Just stick a knife blade at the bottom of the cover and pry very easy. The crack is big enough for the blade to go in and it will come up where you can get your fingers under and pull off. It just snaps off and snaps back on. Be easy and every thing works great.
