Do you plan on keeping the stock amp? Either way Metra makes a harness kit that can be bought at www.crutchfield.com Very nice unit by the way you will be happy with it. Don't worry about mounting it, its not a big deal you will use the stock mounting brackets on the old radio to bolt right up. Did you get the XE bezel? You will not need a special antenna adpater. Give me more details on your plans. thanks
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
