Old 01-04-2005, 09:22 AM   #1 (permalink)
1BadTitan's Avatar
Speed Reference Wire For Nav???
Where is the speed reference wire. I need to tap into this for the navigation on the eclipse avn2454. I need to tap that, and the reverse wire. The reverse wire is just tapping into the brake light wire. But I need the speed ref.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
Old 01-04-2005, 09:53 AM   #2 (permalink)
TIsTAN's Avatar
got this from the cheat sheets used in my install, direct from directed...
Reverse Light, green/white, + polarity, inside rearview mirror
Speed Sense, white/red, 8P, cluster or shift lock control unit
TIsTAN is offline   Reply With Quote
Old 01-04-2005, 09:59 AM   #3 (permalink)
1BadTitan's Avatar
8P...Whats that. 8 pin connector? Or pin #8
1BadTitan
Old 01-04-2005, 12:12 PM   #4 (permalink)
TIsTAN's Avatar
not sure, just copying the info. but i think it is pin 8 since it mentions the location and polarity should not matter.
Old 01-04-2005, 12:23 PM   #5 (permalink)
markislive78's Avatar
Here ya go..
Where you would want to pick it up is on connector M98, pin 24. It's the only 24 pin connector that plugs into the factory radio. If you have the PDF manual look at page 26 of the PDF file for the AV section. This is the line that feeds the speed-sensitive-volume control. Hope this helps....cheers
markislive78 is offline   Reply With Quote
Old 01-04-2005, 09:08 PM   #6 (permalink)
1BadTitan's Avatar
What color is it on the 24 pin harness? Is it numbered?
1BadTitan
Old 01-05-2005, 06:04 AM   #7 (permalink)
TriKKy's Avatar
I posted a link to this in the other thread about this.......
http://forums.freshalloy.com/ubbthre...e#Post67561146
I don't know if the wire color is the same but I am positive the number is the same (looked it up in the manual)
1.
Old 01-05-2005, 07:07 AM   #8 (permalink)
1BadTitan,
Look at either the top or the botom of the 24 pin connector.... the pins will be numbered...they are very small you may need a flash light. Ofcourse since it's pin 24.. it will be the last conductor on that connector. Sorry i don't remember what color the wire was
Old 01-05-2005, 11:42 AM   #9 (permalink)
1BadTitan's Avatar
Pin 24...Is that the one you used as the speed sensor wire for your nav? And it works good?
1BadTitan
