Old 01-05-2005, 02:19 PM   #1 (permalink)
How much gunk was on your rear diff plug?
I finally got around to changing my fluid yesterday(after 3k miles) and I was surprised as to how much crap was on the plug. It was at least a 1/2 " high on the plug and the fluid had a grayish color to it. At least it was full from the factory. I refilled it with M1 75-90 and I plan on doing it again at 5k.
Lou
'04 CC XE Radiant Silver
Born: Sept 04, 2004
Air box mod
Bug deflector
Westin Step Rails
Splash Guards
Keyless Remote
All around tint
Jet Tech Trac-Bars
Hi,I'm Troy McClure. You may remember me from such films like: "P is for Psycho", and "The President's Neck is Missing".....
Lounatk is offline   Reply With Quote
Old 01-05-2005, 02:26 PM   #2 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Thumbs up Small amount of paste on both differential plugs
Vey little grey paste like never seize..no metal pieces...and the same for the front diffie by the way. A little over 4,000 miles too. Tom
honeykeeper is offline   Reply With Quote
Old 01-05-2005, 02:28 PM   #3 (permalink)
azxr's Avatar
Changed mine around 4600. Was full, but very black. Didn't smell and almost nothing on the plug. There was a minute amount of grey paste on part of the plug thread area.
I put in Valvoline 80-90 semi-synth or something like that. I will be changing it when I hit 10K with full synth. Not sure if I will go to the 75-140 or stay with the recommended weight for an 04.
_________________________________________
2004 Titan SE KC 4X4 - Pearl White
Born on 7/14/2004
Purchased on 8/28/04
SE Off Road Package
SE Utility Bed Package
Rockford Fosgate with Power Captain
azxr is offline   Reply With Quote
Old 01-05-2005, 02:32 PM   #4 (permalink)
TYTAIN's Avatar
Lou
That's a little more gunk than mine had at 6k, but you shouldn't need to change your fluid for a while now. The diff should be pretty well broken in now you probably won't see much metal from hear on out. But that's completely up to you.
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 01-05-2005, 02:37 PM   #5 (permalink)
TYTAIN's Avatar
Hope that doesn't start another debate ,some people go by Nissan specs in the owners manual, some go by what Joe Bob Billy the cheif mechanic and bottle washer at the dealer say. I say put in what you want!
PRG Shackles
Old 01-05-2005, 03:28 PM   #6 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
I thought the grey paste was a sealer of some kind on the plug? I had almost zero crappolla in my rear diff and the plug had a little of the grey paste on it at 3k.
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 01-05-2005, 03:32 PM   #7 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
The grey paste is assembly lube that is used in the diff bearings.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 01-05-2005, 03:34 PM   #8 (permalink)
5200 miles when I changed mine... no metal shavings just the grey stuff they used during assembly was found on my drain plug. All I can say is MAN the differential fluid reeked!
puddlejumper is offline   Reply With Quote
Old 01-05-2005, 05:52 PM   #9 (permalink)
rholland's Avatar
Same here, really was no reason to change mine, but I did.
Ride it, like you stole it
rholland is offline   Reply With Quote
Old 01-05-2005, 07:26 PM   #10 (permalink)
caltitan's Avatar
Fluid level was fine from the factory. When I changed at ~5500 it was a very dark gray with no shavings and a little gunk on the plug. Put in semi-synthetic 85W/140.
2004 Titan SE KC 2WD
Flowmaster 70 Series Muffler, Magnaflow Resonators, AEM Dryflow Intake, Airaid TBS, Uprev Osiris Flash, ECO-3, Big Tow Package, ActiveTuning Grounding Kit, Crown Performance SS/Kevlar Brake Lines, PRG Leveling Kit & Rear Blocks, Nitto Terra Grappler 285-60-18 Tires, Truxedo Lo Pro Tonneau
caltitan is offline   Reply With Quote
Old 01-05-2005, 09:49 PM   #11 (permalink)
I thought it odd that the front diff. had two magnetic plugs while the rear had one. Is mine the only one this way? If not, any particular reason for this ?
sndmn2 is offline   Reply With Quote
Old 01-05-2005, 10:12 PM   #12 (permalink)
RockyMtnTitan's Avatar
Tom, do you recall how much fluid the front diff takes. I think manual calls for 3.4 pints, but not sure if this is correct, since the capacity for the rear diff listed in the manual was 3.6 pints and actual is just over 4.
BTW....did my rear diff at about 3000 mi. No metal, no bad odor. Used M1 75W-140, will probably stick with 75-90 for front since it won't be seeing the kind of heat the rear sees.
Thanks,
Steve
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 01-06-2005, 11:12 AM   #13 (permalink)
Cool. That's why I had so much on the plug. You think that Nissan went ahead and gave the bearings an extra shot of grease on the newer models? I know, stupid to ask, but you never know.
Lou
Born: Sept 04, 2004
Air box mod
Bug deflector
Westin Step Rails
Splash Guards
Keyless Remote
All around tint
Jet Tech Trac-Bars
Old 01-06-2005, 12:42 PM   #14 (permalink)
GA-matt's Avatar
Changed mine around 3K miles and had the sludge at the bottom, a few small metal shavings, dark colored fluid with a bad burned smell. Fill level was just below full. I about 2K miles into M1 75w140 with no problems.
2004 Nissan Titan Crew Cab SE - Smoke
  • Off-Road
  • Big Tow
  • Utility Bed
  • SE Popular
  • Captains Chairs
  • Side Air Bags
  • Rockford Fosgate System
  • Delphi Skyfi 2 XM Receiver
GA-matt is offline   Reply With Quote
Old 01-06-2005, 10:39 PM   #15 (permalink)
NorCal 4x4's Avatar
Checked level and condition at ~2000 miles - both F/R were full and in very good condition.
Changed GL at ~8000 miles. Both F/R drain plugs very dark but very little build up of debris, maybe 1/16" or less.
Replaced with Schaeffer 267 Supreme Gear Lube. A Synthetic Blend, 80W-90 that exceeds GL-5. This stuff is a paraffin base oil formula blended with synthetic base stocks, and Moly as a friction modifier. Also contains "adhesive-cohesive" additives for climbing. Good down to -22° F and up to 250° F greater than dino GL.
