Old 01-05-2005, 02:27 PM   #1 (permalink)
Adding a power rear window to 2004 SE CC?
I did use the search on this but most of the info came from before the 2005's were out and so had to do with aftermarket windows.
How hard do you all think it would be to change the rear window on a crew cab to a power window? I like having that rear window down but, unfortunately, can't reach it.
Anyone done it and have info to share? Thanks in advance...
jdmartin is offline   Reply With Quote
Old 01-05-2005, 03:18 PM   #2 (permalink)
6thsense's Avatar
I dont see that being a cheap upgrade....but if you want it and have the money...more power to you....does anyone even sell the parts to do that?
6thsense is offline   Reply With Quote
Old 01-05-2005, 03:23 PM   #3 (permalink)
Gearman1987's Avatar
Try this Forum Link - this guy did it
power sliding rear window installed!
Gearman1987 is offline   Reply With Quote
Old 01-05-2005, 03:31 PM   #4 (permalink)
jmacougar's Avatar
You definitely can't add the Nissan window to the KC. When I first saw the 2005 CC at the State Fair of Texas I looked behind the seats and the rear wall was thicker in order to allow the window to roll down inside.
jmacougar is offline   Reply With Quote
Old 01-05-2005, 07:53 PM   #5 (permalink)
http://www.titantalk.com/forums/sho...wer+back+window
I was looking for a factory window response; already saw the aftermarket window issue. Somehow, it doesn't seem to me that it would be all that difficult to do. Whether or not it would be expensive is something else altogether. Unless Nissan redesigned the cab completely to hold the power window, it seems to me that it is probably just a different window, a motor and switch, and maybe a different trim panel on the back wall.
Anyone else got any info?
Old 01-06-2005, 02:41 PM   #6 (permalink)
smoketitan's Avatar
so in the 05 the window rolls down and not to the side?? seesm odd that they woudl redesign the entire back wall from yea rone to year two
