Go Back   Nissan Titan Forums > Titan Discussion > Titan General Discussion
User Name
Password
Cure for accidentally turning off lights 63˘! - being discussed at Nissan Titan Forums in the Titan General Discussion section.
Old 01-08-2005, 07:44 AM   #1
honeykeeper
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Thumbs up Cure for accidentally turning off headlights 63˘!
This isn't my idea.....saw it on TT but could not find the thread or inventor.....to fix the loose on/off switch when hitting the highs at night put an o-ring at the pivot joint on the right side of the switch.....one o-ring does the job and darn well too....FAUCET 1-3P.....Part#780054 O-ring
1-1/4 x 1 x 1/8....Price dode:C Quantity 1 Lot#HO996969 Made in Taiwan....now for the cost of this....59˘ tax 4˘=63˘.......best under 1$ fix you'll find. Thanks to the person who came up with it on titan Talk!!.Sorry I could not find the thread!!...Peace-Tom.. Bass Ale
honeykeeper is offline   Reply With Quote
Old 01-08-2005, 08:08 AM   #2
daschtick
daschtick's Avatar
I noticed this loose switch issue on a truck I test drove, and I accidentally hit the switch 3 times during my test drive. On the other hand, I have never done this on my truck.
That said, you have a defective switch, get it replaced under warranty.
2004 Red Brawn/Graphite
King Cab, LE, 4WD, Big Tow
Truxedo Low Profile (Utilitrac), Magnaflow 5x11 Polished Muffler
OEM XM receiver, Infinti QX56 Center Console Armrest
Born 8/24/04, Delivered 9/8/04
daschtick is offline   Reply With Quote
Old 01-08-2005, 08:13 AM   #3
honeykeeper
Question Aren't they all loose????
You mean yours isn't loose???? I thought they all were???? I'll add it to the list for my next bi-weekly warranty work!!lol Bass Ale
5/04/Born 10/15/04 Adopted SEKC Pearl White Graphite/Titanium Interior Popular Package, Bench Seat and “Sweet” Column Thumbshifter, In-Cabin Microfilters, 4 x 4 Off Road with Big Tow and E-loc...ARE Z shell..OEM bug/rock deflector, OEM mud gaurds, Bushwhacker Fender Flares, OEM rubber mats, Utilitrac with Lower Sliding Tray, Silver Star Low Beams, White Knight Backup Lights, 75-140W Valvoline Synthetic In Rear & Front Differentials , Drawtite Activator II trailer-brake control
6 x 10' low bed/rails trailer, 100 year old rebuilt 4,000 lb. road roller/packer
Old 01-08-2005, 08:25 AM   #4
PA Titan
mine is loose although I have a 2004 with a build date of 10/03
PA Titan is offline   Reply With Quote
Old 01-08-2005, 08:29 AM   #5
jhromy
Banned
jhromy's Avatar
i dont find mine loose...never happened once to be before or after changing the switch for the fog lights...
jhromy is offline   Reply With Quote
Old 01-08-2005, 01:43 PM   #6
daschtick
daschtick's Avatar
Originally Posted by Tom Mincarelli
You mean yours isn't loose???? I thought they all were???? I'll ad it to the list for my next bi-weekly warranty work!!
Correct. The switch on my truck is 'normal', but the switch on the truck I test drove was very loose. Check the operation on an '05, and you will probably notice quite a difference.
Old 01-08-2005, 02:39 PM   #7
honeykeeper
Thumbs up I like the o-ring!~!!
If there is no TSB and it has a minor limp hold to it..do you think it is under warranty???? Tell you the truth the o-ring works like a champ......someone else here should try it and report in!!!lol I will check some 05's next week for this and other charachteristics.....already planned..thanks..Peace-Tom
Bass Ale
Old 01-08-2005, 03:05 PM   #8
smoothTitan
smoothTitan's Avatar
i have never experienced this either.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 01-08-2005, 04:58 PM   #9
pagerdaddy
pagerdaddy's Avatar
I happened to do this one night when meeting another car on a two lane road. Instead of taking my left hand off the steering wheel, I just reached out with my middle finger to pull the lever. Damned if I didn't turn off the lights instead.
When I tried duplicating what happened, I discovered that what I must have done was to pull on the end of the lever near the top, which rotated the light switch to the off position. This won't happen when I pull it with my finger in the very center, or below the center line of the lever.
It apparently takes less force to rotate the light switch than it does to flick the lever for high/low beam.
Steve
pagerdaddy is offline   Reply With Quote
Old 01-08-2005, 07:24 PM   #10
rjspitz
rjspitz's Avatar
This happens to me all the time when I flip the turn signal. I'll have to try the O-ring trick.
Thanks, whoever!!!
Old 01-09-2005, 04:48 AM   #11
smoothTitan
I usually dont have to use the high beams that often. those darn things are really bright. seems like i alwyas get behind a little car and my lights shine directly in ther rear view mirror. you can see heads turning and hands in front of their mirror, maybe i could adjust them down a little because they are a little high.
you guys have this problem.
Old 01-09-2005, 05:36 AM   #12
honeykeeper
Thumbs up Not a problem now!!
I drove up the Blue Ridge Parkway last night..twisting and turning and high/low beams and other vehicles constantly....guess what???? Never turned the lights off once by accident....so it works very well for me. I will ask the dealer to check my switch out to make sure but the o-ring stays on for now!
I owe someone here a Bass Ale Thanks Tom
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow and E-loc Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Hellwig Anti-Sway Bar, PRG: Bilstein 5100 shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Bilstein Front Shocks, In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod., NISSAN I-POD adapter, Bosch Icon blades.
6 x 10' low bed/rails trailer with E-brakes.
108 year old rebuilt 4,000 lb. road roller/packer.
Amsoil Testing: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Series 2000 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter
60 MPH/20.50 MPG ***New Record-23.01 MPG***
"We have the Capability &Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
Old 01-09-2005, 06:24 AM   #13
garo1
garo1's Avatar
I haven't had this problem yet. Is it the switch that's defective or is it just being aware?
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 01-09-2005, 06:46 AM   #14
Nuckle
Nuckle's Avatar
I have a 2004 build date of feb04. I cant think of a single time that I have turned my lights off while switching them from lo to high beam. It may be my fat fingers.
Nuck
Nuckle is offline   Reply With Quote
Old 01-09-2005, 06:59 AM   #15
greg w
It's the switch. I had mine replaced by the dealer. It's better than the original but still can happen. I since have installed a DRL system that switches my lights grom 75% daytime to 100% at dusk and thus basically eliminated the use of the factory switch. It still operates but I don't need it.
The service manager and I went out on the lot and tried all the Titans and all would go off too easy. Then we tried the Altima with the same switch and you can't make it happen.
I reported it to the OSD several months ago and so far I'm the only complaint so nothing has been investigated.
I feel this is a dangerous safety defect and everyone should report it to both the OSD and Nissan.
It should take more force to rotate the switch barrel , the foglight switch is hard to find without turning off your headlights, the headlights shouldn't be on the stalk that is constanly used in driving-move it to the other side, and please put an indicator light on the instrument panel to tell me when the foglights are on!!!
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
