Old 01-08-2005, 03:16 PM   #1 (permalink)
Oil Capacity question
Is it me or does everyone elses Titan take more than 6 1/2 quarts to fill to capacity? Mine takes like 7 1/4. I was just wondering cause it's taken that the last two oil changes.
John C.
TexasTitan04 is offline   Reply With Quote
Old 01-08-2005, 03:20 PM   #2 (permalink)
garo1's Avatar
That's what I see too. I usually put 7 1/2 quarts in mine.
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 01-08-2005, 03:25 PM   #3 (permalink)
Good, I'm glad it's not just me.
Old 01-08-2005, 04:00 PM   #4 (permalink)
mhwo's Avatar
I put 71/2 in at every change.
mhwo is offline   Reply With Quote
Old 01-08-2005, 04:03 PM   #5 (permalink)
smoothTitan's Avatar
are you filling to the top line
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 01-08-2005, 05:58 PM   #6 (permalink)
rholland's Avatar
It takes 6 1/2 qts with filter, regardless of what you see on the dip-stick.
Half way between the two holes should be full.
Ride it, like you stole it
rholland is offline   Reply With Quote
Old 01-08-2005, 06:10 PM   #7 (permalink)
7qts. of oil, 1 can of STP, Make sure to let the engine drain down completely before checking the oil!!!!!!!!! Yeh I STILL and ALWAYS WILL USE STP!!! in EVERY (11) engine that I own!!!!
drags1998 is offline   Reply With Quote
Old 01-08-2005, 06:34 PM   #8 (permalink)
vector6's Avatar
i just changed mine today and rotated the tires... it took 6 3/4 quarts to the H mark.
2006 jeep RUBICON so long titan...
No News with Combat Crews
vector6 is offline   Reply With Quote
Old 01-08-2005, 08:08 PM   #9 (permalink)
tnbowhunter's Avatar
I go strickly by the book 6 1/2 qts.
If it's off a little on the stick so what.............?
2001 Polaris Sportsman 500.
Old 01-08-2005, 09:55 PM   #10 (permalink)
Banned
I didn't even see anything on the dipstick with 6 1/2 qts. So not wanting to go over but wanting to be "safe", I out in the rest of the 7th qt.
Titan2004 is offline   Reply With Quote
Old 01-08-2005, 10:11 PM   #11 (permalink)
Banned
Squid's Avatar
Some people don't realize you need to give the oil time to drain into the pan.
Wait 30 minutes and then check it.
Squid is offline   Reply With Quote
Old 01-09-2005, 03:59 AM   #12 (permalink)
7 1/2 quarts has to be way up on the dip stick...
Trenz billet
15% tint
Old 01-09-2005, 09:41 AM   #13 (permalink)
QWIKWHIP's Avatar
I put 7 1/2 quarts in on my last oil change to fill it (about 400 miles ago). I just went out and checked the oil after the truck has been sitting in my garage all night and it still read on the full mark. I will continue to use what the dipstick tells me to.
Old 01-09-2005, 01:04 PM   #14 (permalink)
yea the owners manual says the operating range is between the 2 marks not the top mark.
Trenz billet
15% tint
Old 01-09-2005, 05:39 PM   #15 (permalink)
I do realize that you have to let the oil drain....but I do not care what the manual says.....just like the fill capacity on the rear diff.....but to even come close to the fill line in my truck it takes 7 quarts......go figure..
John Chapman
