At the dealer for my 4th brake TSB last week. Service writer did the "you didn't hear this from me - BUT - The rotors in the Titan are from the Frontier and to small. Nissan will be providing a new, large rotor fix in the near future".
They know I am at a point of "lemon law" in CO - although they also communicated that the lemon law only applies if I am refused service. I will check into that one further.
Overall the dealer has taken very good care of me considering some of the titan issues with brakes and rattles. I really like the Titan and can't wait for a a real fix to the brakes as I know I will also need it if I do end up with an 05.
I would have looked at the Service Writer and said "NO SH!T - REALLY - The Brakes are too small - that would explain my multiple trips here!" (by the way I mine was ready for it's 3rd set when I traded it at 22,000)
Unfortunately, other vendors seem to have been able to offer a "fix" before Nissan sould get to it:
It will be interesting to see how they address the 17 and 18" wheels????? Two different size fixes???
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac.
In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
So why is it that not all of us have brake issues? I have over 7,000 miles and don't have any of the juddering or warping problems mentioned on this site. Build date on mine is 8/4/04. Does that have something to do with it?
I don't have any problems either but there are some people that have gotten it at 2kmi and others didn't get it till over 10kmi. I'm guessing driving styles have alot to do with it.
Just hook you a 4 or 5,000 lb. trailer on that has no brakes and tow it around a few days. You will have the judder in no time.
Maybe that's why you have the brake judder than. Your crazy to be towing that much with no brakes. Not only does it over work the trucks brakes, but it's just plain unsafe! The trucks brakes were not meant to stop the truck plus 5k pounds. Please read the manual and tow safely.
This is from the owners manual.
When towing a trailer load of 1,000 lbs.
(454 kg) or more, trailers with a brake system MUST be used.
I'm sure Nissan will put a recall/campaign on bigger brakes just like I will win the lottery worth millions....lol I can honestly say that I have never had any issues with my brakes other then spongy feeling compared the Maxima. I don't have any judder or vibrations issues at this time...
__________________ 2007 Toyota Tundra DC SR5 TRD 4X4
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
i think cause your build date had the new brake set, not sure if that's even a true asessment.
my theory as to why you don't have problems is because its so damn COLD in wisconsin the subzero wind chill probably cools the brakes down before they get too hot to warp, i dunno - just an idea...
I'm crying foul here. I've towed for years and with many different vehicles. Do you mean to tell me my single axle enclosed trailer, with a gtw of 3500 lbs needs to be retrofitted with trailer brakes? If thats the case then the Titan has some of the worst brakes imaginable on a vehicle.
As it stands now I don't recall any single axle trailers in the sizes that would be normally towed by these vehicles having a supplemental braking system.
I'll continue to ignore the warning about 1000+ lb trailers and tow like i've always been. None of my other vehicles had braking isssues and one in particular, my 99 F350 SD Diesel saw it's first front brake replacement at 102,000 miles. I did plenty of towing with that.
Sounds to me like the brakes are wholly inadequate, Nissan wrote the manual to account for that and we're being given a safety snow job.
I have a build date of 7/04 and have the brake issue. I drive hard on my brakes. I think everyone has it, but its just a matter of time depending on driving style until noticed.
I hope I am wrong.
I'm not gonna question or argue about anybodies towing habits, I'm just stating what the manual says. And yes, if you lived in NY (and many other states) you would have to retrofit brakes to your trailer because it's the law. Anything over 1000 pounds must have brakes or it can't be registered. And I'm not denying that there is a brake problem, I am well aware that there is an issue. I think the brakes a plenty strong enough to do the job, I just think there is a problem with the parts being used.
My dealer urged me not to do the second fix (last week) b/c their Factory rep told him the "perm fix" will be rolling out at the end of Jan or early Feb.
I'll believe it when I see it...hope I see it soon.
perhaps because warping is caused by heat and you live in snowy WI?
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
