Old 01-13-2005, 07:13 PM   #1 (permalink)
Squeky noise from rear shock
2 months ago I installed the front wards helper spring fix. Now my right rear shocks sometimes squeks when I run over minor bumps. Any one else have this problem. thanks
PA Titan is offline   Reply With Quote
Old 01-13-2005, 07:34 PM   #2 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
SEARCH..someone had a squeeker not long ago.was deformed..Tom
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac.
In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 01-13-2005, 07:57 PM   #3 (permalink)
I remember someone else posting about fixing a squeeking shock by replacing it with a real rubber boot. Search away.
Ape0r is offline   Reply With Quote
Old 01-14-2005, 09:48 AM   #4 (permalink)
I had a squeek and it turned out to be leaf spring, not shock. Sprayed a little wd40 on it and all was fine.
jd1973 is offline   Reply With Quote
Old 01-14-2005, 11:50 AM   #5 (permalink)
That could be my problem I will try to wd 40 it and see if the squeek goes away. Thanks
Old 01-14-2005, 02:31 PM   #6 (permalink)
Banned
Squid's Avatar
Hi, was reading about your squeek and here is a link that has a picture of where a lot of us have to periodically lube.
Squeaky suspension
Squid is offline   Reply With Quote
Old 01-14-2005, 03:57 PM   #7 (permalink)
Titanoholic's Avatar
I did a write up on this about a month ago. The fake hard plastic rancho boots were rubbing against my shocks causing a high pitch squeek. I removed the cheap plastic boots and replaced them with real rancho rubber boots. Squeek fixed. Plus it looks and function a lot better then the cheap look alikes.
AKA GoCougsKev
2005 Silver Titan LE CC 4WD
Born on 11/04
Adopted 11/04
Navigation System, DVD, Sunroof, Big Tow, Off Road, Side/Curtain Airbags
A.R.E Z Series Canopy
E&G Classic Billet Grill
OEM Bug Deflector
Prodigy Brake Controller
Titanoholic is offline   Reply With Quote
Old 01-14-2005, 04:31 PM   #8 (permalink)
Thumbs up Is it under warranty?????
I would take it to the dealer....let them test it and if it is under warranty...let them replace it. Might want to take the helper/clamp springs off first.
Peace-Tom st tersas pale ale
