Old 01-14-2005, 09:01 PM   #1 (permalink)
Banned
Send a message via ICQ to Titan_TX Send a message via AIM to Titan_TX Send a message via MSN to Titan_TX
Installed my CarbonTech Bobcat pads from the GroupBuy (Pics)
I took a few photos of the install till my hands got way to dirty to even touch my camera. On one pic you can tell the difference between the stock pad which was on the right and the new aftermarket one.
Install is 15 minutes tops. My oil change took longer. LOL!
Anyways, here are the pics, and the brakes so far after one evening of driving have improved drastically. I no longer need to give much pedal pressure to stop the truck. Much better responding brakes. Time willl tell if it solves the rotor issues. It seems to have for others.
Titan_TX is offline   Reply With Quote
Old 01-15-2005, 07:07 AM   #2 (permalink)
DALGATITAN's Avatar
Did You Have Your Rotor's Turned,or Just Installed New Pads?
DALGATITAN is offline   Reply With Quote
Old 01-15-2005, 07:27 AM   #3 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Question How hard are the new pads?????
How hard are these pads???? I tried hard pads once and it warped the rotors faster than stock on my last truck.....with hard pads I would go with a drilled and slotted rotor to get the heat out faster....might as well change the brake lines too. When warranty is up that is what I will probably do.
Peace-Tom Coffe & Bailey's
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow and E-loc Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Hellwig Anti-Sway Bar, PRG: Bilstein 5100 shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Bilstein Front Shocks, In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod., NISSAN I-POD adapter, Bosch Icon blades.
6 x 10' low bed/rails trailer with E-brakes.
108 year old rebuilt 4,000 lb. road roller/packer.
Amsoil Testing: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Series 2000 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter
60 MPH/20.50 MPG ***New Record-23.01 MPG***
"We have the Capability &Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 01-15-2005, 07:38 AM   #4 (permalink)
Banned
The rotors were replaced one week ago by the dealer. They didn't need to be turned again. As long as they are not warped no reason to turn them.
Old 01-15-2005, 07:41 AM   #5 (permalink)
Banned
The pads is what creates the heat. Better compound pads get rid of the heat much better than lets say the factory organic pads. These pads have been tested by others for a while with good results compared to stock pads and no warping. They have even done some hard hard braking to see if they get a problem to arise.
Cross Drilled rotors or slotted rotors do not get rid of the heat faster. A bigger rotor with better fins will. Cross drilled rotors and slotted are made to get rid of the gases between the pad and rotor, and also are made to keep the pads from glazing by scraping the pads. But in turn creates more heat due to friction.
But when you have these rotors they have less surface area so they tend to either warp or crack faster by heat.
Old 01-15-2005, 08:09 AM   #6 (permalink)
Larger rotors and pads yes...but my only attempt with the carbon ones did not work for me in the past.
5,200 miles on stock rotors....on mountain.a$$ conditions... new TSB pad etc. at 4,200 miles but still untouched rotors!! I hope those with the carbon tech pads report miles and wear. Peace-Tom
Old 01-15-2005, 08:17 AM   #7 (permalink)
Banned
These aren't fully carbon. Read this article for a full review..
http://www.nissanperformancemag.com/december04/titan/
The Bobcat is a ceramic-based friction compound that is rotor friendly, operates over a broad range of temperatures, is low dusting and makes very little noise.
They have, Do a search at clubtitan.org and you will see.
