Old 01-17-2005, 09:21 AM   #1 (permalink)
wareagle's Avatar
wiring under dash and what they do, wire diagram
Maybe this will help someone when trying to install something, I installed the aftermarket power locks this weekend but didn't do the keyless b/c couldn't find this diagram till today and my brother left town now. Oh well will do later. I took a good picture of my install but I am going to re-do the power wires b/c I had to run independant power wires to the battery b/c didn't have this info. Oh well works great for now anyway. I will post a how to later on the power locks.
here is a link to the site and all of the explanations http://www.directechs.com/directwire...emote%20Start#
also here is what is on that site just in case it changes
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2004 / Remote Start
[PRINT THIS PAGE]
12volts green (40A) + ignition harness
Starter brown + ignition harness
Second Starter lt. green or blue/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory purple + ignition harness
Keysense red/blue to black/red + ign harn or BCM R of column, pin 37
Power Lock blue - driver door module in door
Power Unlock red (double pulse) - driver door module in door
Lock Motor purple 5wi BCM to right of column, pin 65
Unlock Motor green 5wi BCM to right of column, pin 59
Parking Lights+ red/blue + dimmer switch on dash
Parking Lights- N/A
Hazards white/black - BCM to right of column, pin 29
Turn Signal(L) green/black + BCM to right of column, pin 60
Turn Signal(R) green/yellow + BCM to right of column, pin 61
Reverse Light green/white + inside rearview mirror
Door Trigger see notes - BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is red/blue in pin 12. The LR door trigger is red/yellow in pin 48. The RR door trigger is red/white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision blue - BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use red/white in pin 62 at the BCM.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse on power unlock
Tachometer NOT white/blue or black ac any ignition coil
Wait to start N/A
Brake Wire red/green or red/black + brake pedal switch
Parking Brake green - parking brake switch or cluster
Horn Trigger red/white - steering column
Memory Seat 1 lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: N/A
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
04 KC XE SILVER
wareagle is offline   Reply With Quote
Old 05-12-2005, 06:55 PM   #2 (permalink)
Thanks alot! This should help me a ton when i actually install my power door locks and power windows.
hipnotik is offline   Reply With Quote
Old 05-12-2005, 06:56 PM   #3 (permalink)
btw wares... me and you have twin trucks hahah.
Old 05-13-2005, 08:01 AM   #4 (permalink)
DeTitan's Avatar
Yooo WarEagle
Kudos
Thanks
Great find and mighty nice of you to share.
DeTitan
2005 Titan LE 4X4 Crew RadSilver
Side Air Bag/Curtain Pkg w/VDC!
MOD: Circular rotating blind spot mirror.
DD 12/30/04
DeTitan is offline   Reply With Quote
