Location: Albuquerque, NM --> moving to Bismarck ND 7/05
Grinding/Moaning sound while turning left
Wondering if any of you have experienced a grinding sound while turning your Titan? Mine started a couple of days ago, particularly while turning to the left. I *thought* it might be an early sign of the dreaded brake judder, but it occurs everytime the wheel is turned to the left, regardless of speed or whether or not the brakes are being used. The sound appears to be coming from under the right wheel well though it is hard to pin down. I only have 1500 miles on it, and I would say it started around 1200.
I have a scheduled appt. with service on Monday, so hopefully they can get to the bottom of it without any serious dent in my wallet (or the truck while they drive it).
If anyone has any thoughts or suggestions let me know.
Thanks,
Brake judder is while traveling at any rate of speed and applying the brakes. The "warping/deposit coated rotors" cause the whole vehicle and steering wheel to shimmy or 'judder' when you do this. There is not typically any kind of grinding sound when turning associated to brake judder.
Turning the wheel and hearing that leads me to believe that you are driving with your truck in 4X4 and not 4X2 mode. Is this correct? If so, the front wheels are not spinning at the same speed as the back, if not, you have something entirely different going on.
I would drive it in a parking lot and turn to the left and when you start to hear that grinding sound, stop the vehicle where it's at and put it in park. Then get out and look to see if anything is rubbing or catching in the right wheel well. Check the both joints up and down and make sure the wheel is not touching anything, like the inside of the fender.
[quote=logicjunky]
Right. I first noticed the sound while coming down a parking garage, turning left and touching the brakes. That was why I originally thought it was "judder". Since then I have noticed that it only occurs when turning the wheel, totally separate from brake use at all. It has definitely gotten worse over the past few days, and is far more prominent at 10-20 mph.
Definitely not in 4x4. Can pop in and out of 4 Hi without any problem.
Yeah, I've tried that several times and can't see anything that easily explains it. I was definitely hoping it would be that easy to get to the bottom of it, but so far obvious explanations for it have eluded me. If the dealer finds anything I'll post it.
Well, hmmm...use your parking brake much? Maybe a caliper is hung up and jamming the pads down on the rotor and chewing them up? Just guessing on that one.
I started noticing the same problem about a month ago, except that mine makes the noise if I'm turning to the right sharply instead of left. The noise comes from the right front. Two days ago, I finally decided to inspect the area to see what's up. Apparently, the right front tire's sidewall on the inside has been rubbing against the tirewell (black plastic piece) when the steering is turn to the right. I could easily tell because the area that's rubbing against the tire looks clean and shiny. The part looks to be securely attached and not deformed. Your problem may not be the same as mine, but just in case.
'06 White 4x2 CC LE w/ Big Tow & Bench Seat
San Antonio, Texas
Thanks, Masa -- I'll go out an take another look. Have you noticed any wear on the inside edge of your tire as a result? Do you feel any drag while turning? What are you going to do to remedy the problem?
HighDesert......if it's not there..check your steering system.....rack-rods-ends etc.Tom
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac.
In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
[quote=HighDesert]Have you noticed any wear on the inside edge of your tire as a result? Do you feel any drag while turning? What are you going to do to remedy the problem?QUOTE]
I saw no visible sign of wear on the tire although the tirewell piece clearly looks wearing down where the tire comes in contact with. The contact area is too small to create any kind of drag that you can actually feel. Since this problem developed after I submitted my claim form and supporting documents to BBB Auto Line for vehicle replacement, I won't do anything about it... Good luck!
San Antonio, Texas
