Originally Posted by logicjunky
I know some guys around here that have 'ricers' and they say the Silverstars are junk. They burn out too fast. One guy I work with has an Acura RSX and another has the big bad NSX and one went through 3 sets in 6 months (RSX) and the other went through 2 sets in 2 months (NSX). I'm not sure what other options there are but they discouraged me from purchasing those. Just my $.02
This is true. Stay AWAY from any colored bulb, it is a marketing gimick and a rip off. For less than the cost of 1 silverstar bulb you can get 2 phlips Hi-Vis bulbs. They use higher quality components and are made to tighter specs than other bulbs and shape the beam in a more precise manner. There is more to lighting than wattage and how many K a bulb is.
Anyone know what ga the headlight wiring is? If it is like most it is undersized and could benefit from a headlight relay kit to up the voltage to what it SHOULD be. I did this on my car and the lighting was noticably better and I ended up with a more reliable headlight circut. My car had 18ga and I upgrades to 14ga. You can test the voltage drop from the headlight socket with a multi meter to see what you would have to gain.
S.O.
