Old 01-22-2005, 11:21 AM   #1 (permalink)
Diff fluid re-fill
What's up guys and gals,
what is the best way to re-fill your diffs? I usually buy one of those small pumps, but it takes so long to fill. Can I just put a funnel on a hose and empty the bottles into it? I've done this before, but just wanted to see if any of you have better ways to do this. Also, what do you think about putting the heavier synthetic in the 04' diff opposed to the required weight?
aloha, Derrick
grpape is offline   Reply With Quote
Old 01-22-2005, 11:24 AM   #2 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Thumbs up Welcome to Titan Talk!!!
grpape......welcome to Titan Talk......use the SEARCH button......you'll get all you want on this one!!!lol Peace-Tom Bass Ale
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow and E-loc Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Hellwig Anti-Sway Bar, PRG: Bilstein 5100 shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Bilstein Front Shocks, In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod., NISSAN I-POD adapter, Bosch Icon blades.
6 x 10' low bed/rails trailer with E-brakes.
108 year old rebuilt 4,000 lb. road roller/packer.
Amsoil Testing: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Series 2000 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter
60 MPH/20.50 MPG ***New Record-23.01 MPG***
"We have the Capability &Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 01-22-2005, 11:26 AM   #3 (permalink)
HudsonValleyTitan's Avatar
You won't need anything. The front is a PITA to get the bottle high enough to squeeze it in once the bottle is half empty so I just bought another quart and was about to fill it that way. The rear is simple. The Mobil1 I used comes with a handy pointed filler nozzle.
Old 01-22-2005, 12:29 PM   #4 (permalink)
Thanks for the welcome Tom,
Yeah, I usually use the search button, but I wanted to post something to say "Hi" to everyone.
aloha, Derrick
Old 01-22-2005, 12:30 PM   #5 (permalink)
I use Mobil 1 75-90w. I have some difficulty refilling the rear differential because the spare tire is in the way. I bought a Flow Tool which is a clear plastic tool that screws onto the plastic Mobil bottle. You can twist it to turn the flow on and off and the flexible clear hose lets you see the fluid going in. This makes the process a lot easier. These are sold at almost every automotive parts retailer like Pep Boys, Auto Zone, etc. for just a few dollars. I think the pump thing you add onto the bottle would work well also.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 01-22-2005, 01:15 PM   #6 (permalink)
I got a pump at auto zone for approx $7. Looks like a grease gun with an approx 1/2" hose (guessing at size, it's been a few months since I used.) Stick the end of the hose into the oil and pull the lever to suck oil into the gun, push to pump it back out. Could be used to suck old out if we didn't have a drain hole.
MikeL is offline   Reply With Quote
Old 01-22-2005, 01:28 PM   #7 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
Welcome to the forum grpape. While we are discussing it, what type of sealent do you guys use on the plug threads?
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 01-22-2005, 04:13 PM   #8 (permalink)
Good question SarkaZm. I forgot to add that into my question.
Old 01-22-2005, 05:08 PM   #9 (permalink)
Nissan recommends Permatex 56521 or Nissan 999mp-am002p. I use pipe dope that I already had that has Teflon in it. It says on the jar that it is approved for high temp, high pressure, and contact with petroleum based products. It has worked well for me. Below is the Permatex that Nissan recommends.
http://www.permatex.com/auto/autouh....&item_no=56521
BayouTitan
Popular Package
Utility Bed Package
Born on 12/03
Old 01-28-2005, 08:00 PM   #10 (permalink)
radsterrad's Avatar
Could anyone explain to me why you're changing your differential fluid
on new vehicles, i was always under the impression to wait 100,000 miles.
radsterrad is offline   Reply With Quote
Old 01-28-2005, 09:05 PM   #11 (permalink)
rarjar's Avatar
You can do a search on "rear differential fluid" and get reading material for a long, long time! Bottom line is, most of the Titans come from the factory with low fluid levels. Also, the rear differential gear oil volume is relatively small, thus the factory dino gear oil tends to overheat on a regular basis. Many members have drained (and noticed globs of "gunk" build-up on the drain plug), and then changed the gear oil to a synthetic (Mobil 1 75-90W seems to be very popular). The synthetic seems to hold up better to the heat.
2004 Titan 4x4 Pearl White LE King Cab
Tekonsha Voyager Trailer Brake Controller
OEM Bed Divider
Superior leaf spring helpers
Lund X-terminator bug shield
Graphite/Titanium leather seats
Born-on date 6/10/04
Purchased 6/19/04
"We're all here because we're not all there!"
rarjar is offline   Reply With Quote
Old 01-29-2005, 05:25 AM   #12 (permalink)
Hatchman's Avatar
Even after a few thousand miles of towing the rear diff fluid was burnt, black, and gunked up. Swap it out with Mobil 1 75w/90, easy to do, and no more paint burning off diff cover and smell of propane at gas stops (from the smell of the burnt rear diff fluid venting out the axle.)
Was
2004 SE KC 4x2 Galaxy Black
-Packages: Big Tow, Popular w/Capt Chairs, Utility Bed
-Nissan: Fog Lights, Bed Divider &Extender, Splash Guards, Bug Deflector
-Mods: Banks Monster Exhaust, 20% Window Tint, K&N Drop-N Air Filter w/ Air Box Mod, Weatherflectors, Silverstar Headlights, Nismo Aluminum Oil Cap, Chrome TITAN license frame, Nissan 75W/140 Gear oil, K&N oil filter & Amsoil 5W/30 Syn
-Audio: Phoenix Gold Octane-R 8.0:4, MB Quart RCE 269, Adire Audio Koda 6" Midbass, Clarion SRV-303 Sub, Navone NE-774V, 0/1 ground Streetwires.
Hatchman is offline   Reply With Quote
Old 01-29-2005, 07:12 AM   #13 (permalink)
radsterrad's Avatar
Thanks for the info, would this apply to me even though i don't tow anything.
If i change out the diff fluid to the synthetic mobil 1 how long am i good for.
Old 01-29-2005, 08:01 AM   #14 (permalink)
radsterrad's Avatar
When you refill the diff do you fill it until it starts running out of the filler hole? Like the old trucks.
How much does it hold?
Old 01-29-2005, 08:03 AM   #15 (permalink)
Yes, you just keep filling until it starts to pour back out. It's a little over a QT (of was that a little under a QT..lol) not sure of the exact amount. Nut if it's coming back out, it's full.
