Old 01-24-2005, 06:03 PM   #1 (permalink)
"rattle" in dash and in sterring column...Help!!
Had my Titan for a little over a week now and am experiencing a rattle in the drivers side dash (appears to be coming from the left edge of the defrost plastic panel)..anyway, when I pust down on the very edge of the defrost panel, it stops. Is this the same rattle as alot of members have experienced in the dash (and, if so, did the foam fix work?)....Also, I am getting a rattle type coming from my steering column (the plastic that surrounds the turn signal and wiper levers) when I turn the steering wheel either way. Its sounds like something is either making contact with the plastic as the wheel is turning or something is causing the plastic to expand when turning the steering wheel. What do you all think? So far, other than these little rattles, I love my truck. No other problems thus far!
Paul
Paulphilly is offline   Reply With Quote
