Old 01-31-2005, 01:55 AM   #1 (permalink)
Jaybr's Avatar
5000 miles with 5000lb load
Getting ready for a big test of the Titans towing abilities. Leaving 2/8 towing my 21' enclosed v-nose full of quads from VA to Glamis in SoCal. With 4 quads and all the gear I estimate the trailer weights around 5000lbs.
I towed the trailer to IA back in Oct just after I bought the truck and avg 8.5mpg, hope it does better this time. I only had 1000 miles on the truck when I started that trip, 9000 now, but I'll have a couple extra quads this time so an extra 800lbs or so. We also ran 75-80mph that trip which I'm sure didn't help.
I've changed the rear diff to Redline 80w140 full synthetic, and run a prodigy controller, any other advice you guys can offer?
I also ordered a Truxedo from Jamie at http://www.nissanparts247.com that will go on before the trip.
Jaybr is offline   Reply With Quote
Old 01-31-2005, 11:36 AM   #2 (permalink)
Banned
maybe to change your engine oil since youll be going on a far trip, towing, new oil in the engine would be a good idea, stay safe!!! update us on how the titan towed when you get back, take care
dilleyoshemp is offline   Reply With Quote
Old 02-17-2005, 10:18 PM   #3 (permalink)
Jaybr's Avatar
Got back from the trip yesterday, 4970 miles and no problems at all. Truck towed great other than some wind push when passing the big rigs. We averaged 9.8 mpg and 58.9 mph, not too bad considering the load.
After this trip I've decided I need a bigger trailer, probably a gooseneck.
Old 02-17-2005, 10:26 PM   #4 (permalink)
nmanley's Avatar
Quads in the dunes are awesone weren't they??
Nolan
2004 4x2 CC LE
Black Low Profile Bed tool box, Homemade bed cover, Delphi XM Roady2, Airbox mod w/Fram Air Hog filter, Banks Monster Exhaust installed, Mobile 1 Oil and filter, 85-145 Royal Purple Synthetic Diff fluid, Garmin Zumo 550 GPS, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring Like llajumpvid did his except using two 7" monitors for front and back coverage.
nmanley is offline   Reply With Quote
Old 02-17-2005, 11:29 PM   #5 (permalink)
Jaybr's Avatar
Yes, this was my first time in the dunes and I'll definately be going back.
I took 2 Cannondales, one with a 468cc Falicon stroker motor and what a blast. There where about 20 of us that met up and it was a great trip.
Unfortunatly, my 16 year old son was recovering from a broken collarbone (flipped his 426ex in the whoops section of our mx track) and couldn't go.
Old 02-18-2005, 04:21 AM   #6 (permalink)
TOK
TOK's Avatar
Jaybr, you might already know, but there is a big indoor MX in Harrisburg PA this weekend. Quad and bike classes. I'll be spectating Saturday, I'm too old brittle to race MX, so I stick to the woods.
www.motoramaassoc.com
Tim
TOK is offline   Reply With Quote
Old 02-18-2005, 07:44 AM   #7 (permalink)
Jaybr's Avatar
Tim
lol, I'm too old and brittle to race anything.
My son races some, and alot of friends race, I mainly watch and help in the pits.
After the last week, I better stay home this weekend. I was suppose to go to the Powersports Dealer show in Indy
Old 02-18-2005, 08:46 AM   #8 (permalink)
Warning!!! Nissan does not recommend fifth wheels or goosenecks for
the Titan. If you do decide to put a mount in the bed be very careful
drilling as the fuel tank is close to the bed. You might want to use a
full width plate in the bed to get clearance around the tank. I have
read that people had to remove and move the fuel tank to mount a
fifth wheel hitch. This info was from a towing forum and I do not have
personal knowledge to verify this. Take it as a warning to be careful
and be sure whomever is doing the mounting inspects things underneath
before starting the install. Also you might think of upgrading the tires to
a D rated LT tire to get stiffer sidewalls as both the 17 and 18 inch tires
are not the best for serious towing. If you do use the stock tires I would
be very sure you run with maximum air pressure on the rear tires. Both
types of stock tires tend to have too flexible of a sidewall and it can cause
wierd handling while heavy towing. Good pick on your brake controller I
love mine. If you don't have big tow I would think of adding a automatic
temperature gauge so you know what is going on with the tranny.
Good Luck
Zardoz
Zardoz is offline   Reply With Quote
