Old 01-31-2005, 09:13 AM   #1 (permalink)
Problems with Electric Windows
Over the past few days i have had problems with my drivers side electric window. When i try to get the window back up most of the time no problem, but i have had three instances where i had to play with the switch a few times before it came up. I did a search and found nothing, just wondering if anyone else has had this issue?
cajunscotsman is offline   Reply With Quote
Old 01-31-2005, 09:14 AM   #2 (permalink)
adjmcloon's Avatar
Yeah, pretty widespread issue. I've found that if I wait a few secs the window will come up. Some have had their switches replaced, others the window regulator. I think there's a TSB out.
adjmcloon is offline   Reply With Quote
Old 01-31-2005, 09:22 AM   #3 (permalink)
HudsonValleyTitan's Avatar
That seems to happen if you just "flick" the switch or are playing around with it. It'll reset itself in a few seconds usually.
Old 01-31-2005, 09:22 AM   #4 (permalink)
logicjunky's Avatar
Send a message via AIM to logicjunky
Yep, TSB is out for it. There is a safety feature that interprets the tight window seal as being an obstruction if you try to auto up the window when completely down sometimes. I usually just start raising the window (for about 1 sec) and then click up for the auto up feature. Not a huge issue to me...good luck.
~Radiant Silver K/C 4x4 SE~
~Big Tow, Off-Road Pkg, Utility Bed~
~Born 08/04~
~Adopted 09/04~
-I don't have the answers, I'm just a guy who likes to think and share his ideas...
logicjunky is offline   Reply With Quote
Old 01-31-2005, 09:30 AM   #5 (permalink)
travism's Avatar
Send a message via AIM to travism Send a message via Yahoo to travism
I've had it stop working for me a couple times as well, but waiting for a couple seconds for it to reset and trying again always solved it. Also look at this thread:
Power Window Problem?? Stop Flicking!!
Holding the switch for a second as suggested instead of "flicking" the switch has helped it not occur again for me. My dealer ordered some parts per the TSB, also linked in that thread, back when it first happened and we're waiting on parts for a switch. I don't know if there's a parts backlog because Nissan is trying to fix the situation before releasing new parts, or if they're just behind.
'04 Titan SE King Cab 2WD Deep Water
Popular Pkg w/ Captains, Big Tow
Added: OEM step rails & splash guards, leaf spring helpers, Line-X, TruXedo LoPro tonneau, Wade In-channel window visors
Born 6/3/04, Bought 7/5/04
travism is offline   Reply With Quote
Old 01-31-2005, 09:50 AM   #6 (permalink)
CaptainBay 3000's Avatar
I had the same thing happen when I first got mine, just hold the switch until the window is up an inch or two. It hasn't happend to me since.
CaptainBay 3000 is offline   Reply With Quote
Old 01-31-2005, 10:48 AM   #7 (permalink)
TallTexan's Avatar
Same here. Hold the switch for a second and let go. No problems since I started doing this.
Robert Louis Stevenson
Old 01-31-2005, 11:05 AM   #8 (permalink)
velopede's Avatar
I know we have been through this before, but I did doscover that if I try to use the key lock to roll them up ( which is very rare that I do this), It "confuses" the drivers window and It won't go up. I haven't had a problem in a while with the auto up/down swithc in a long time. I also quit flicking it too. Just my $.02
04' TITAN SE (2WD) Silver, King Cab, Big Tow, Utility Bed, Center Console, Mud Flaps, XM Skyphi2, Fogs, Silverstars, Lund Bug Deflector
"a liger.............bred for it's skills in magic" -Napoleon Dynamite
"I got my azz torn up by a Nissan Titan!"-Caddy SUT Owner-@-Cadillac Owners.com Forums
velopede is offline   Reply With Quote
Old 01-31-2005, 03:35 PM   #9 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
Had my window problem fixed (I hope) with the TSB. Found a temporary fix although that if the drivers window won't come back up, put down the passenger window a little then try and put the drivers window up. Worked for me until I had the dealership apply the TSB
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
Old 02-01-2005, 03:44 PM   #10 (permalink)
I appreciate all the replies..thanks
Old 02-01-2005, 05:16 PM   #11 (permalink)
scott's Avatar
I had same problem with mine. The dealer replaced switches and driver and passenger doors, no more trouble since.
scott is offline   Reply With Quote
Old 02-01-2005, 07:42 PM   #12 (permalink)
titancer's Avatar
I had the window switches replaced in my TITAN a few weeks ago. I have not had any problems since. Take your back to the dealer to have the switches replaced.
TITANCER[IMG]
http://members.cardomain.com/titancer
titancer is offline   Reply With Quote
Old 02-02-2005, 05:58 AM   #13 (permalink)
travism's Avatar
Interesting. My dealer ordered the switches for me about 2 months ago and I'm still waiting for them. Me thinks I need to call my dealer and make sure he's staying on top of things.
Old 02-02-2005, 09:49 AM   #14 (permalink)
mhwo's Avatar
Had the problem, dealer ordered switches, switches showed up in 48 hours, 10 minutes problem fixed.
mhwo is offline   Reply With Quote
Old 02-02-2005, 10:50 AM   #15 (permalink)
keiffers's Avatar
yeah don't wait for the dealer to contact you. You have to follow up on it just as much, otherwise it'll never get taken care of
Keith
"Chester"
SE Popular w/bench
