Old 02-03-2005, 02:07 AM   #1 (permalink)
Unhappy drivers side faint rattle
hey fellow titan owners. i just recently picked up a faint rattle coming from my drivers side door panel. i think it is just above the arm rest. i can only describe the rattle as a faint rattle, almost ticking noise. i can stop the noise when i press against the door panel with my forearm. has anyone experienced this and is there a fix. i am afraid to pull the door panel off as i don't want to f it up. i would greatly appreciate any help with this. i don't really want to take it to the dealership but may have to anyway. thanks, titanrookie
05' black,LE, CC 4x4 offroad w/bigtow
dvd, nav, sunroof with graphite leather interior, leer tonneau cover, bug shield, 20" kaotik chrome rims, magnaflow dual exhaust, train horn, aem brute force cai.
titanrookie is offline   Reply With Quote
Old 02-03-2005, 04:42 AM   #2 (permalink)
Mine does the same thing. I've brought it to the dealer's attention 2 or 3 times while my Titan was being serviced for other problems. Of course each time I got the stock answer ("Unable to locate problem"). The last time they told me to check TitanTalk and if I hear of any TSB's to bring it to their attention and then they will do something about it. It was such an absurd answer that I just dropped it and left and haven't mentioned it again. My wife has a '02 Xterra and her windows do the same things. I just turn the radio up and try not to hear it. I recently filed a complaint with the BBB for the brakes so I'm just waiting to see what happens with that. I'll deal with all of the rattles later if I need to.
Brianyzf is offline   Reply With Quote
Old 02-03-2005, 04:46 AM   #3 (permalink)
By the way mine only seems to make the rattle noise when the window is up. I traced the problem to the window moving around (pushing on the window makes the noise stop) so I thought that once I got my WeatherTech In-Channel Weatherflectors that they would hold the window steadier and the noise would go away. No luck though. The window still seems loose and the noise is back. I'm also afraid to take the door panel off too.
Old 02-03-2005, 05:28 AM   #4 (permalink)
terryu1's Avatar
I noticed a similar "rattle" several times and each time it turned out to be either the driver side or passanger side seatbelt buckle. If no one is using seatbelt (yes I'm guilty often) and the buckle is up higher it taps against the inside door frame very lightly if "just right" . Try sliding buckles down if not in use and see if any change. Just a thought.
'04 Titan LE Crew Cab - Born on 4/30/04
terryu1 is offline   Reply With Quote
Old 02-03-2005, 05:41 AM   #5 (permalink)
mine rattels exactly the same way...just above the driver arm rest. I first thought it was a zipper in my coat, but when I push on the door panel, it stops.
I pulled out on the panel and it felt like the snaps started to give loose...I think it is just the panel rubbing agains the metal door. Some foam strips might need to be glued inside.
jasonwabc is offline   Reply With Quote
Old 02-03-2005, 05:47 AM   #6 (permalink)
Banned
jhromy's Avatar
i have the same rattle, but luckily i have a great service department and they have been working on finding it each time i bring it in...they ordered me a new arm rest because they said one of the clips was missing...i personally dont think its the armrest because it goes away with the window open but it worth the shot....they have taken the door panel off and didn't find any loose bolts or anything...everything was nice and snug...ill have to pay attention to this thread because i would like to know the fix...but like others said its not too big of a deal to me...
jhromy is offline   Reply With Quote
Old 02-03-2005, 04:10 PM   #7 (permalink)
same exact problem
Same deal - goes away with windows down. like a ticking sound from the drivers door. if anyone gets a clue, just post it... drives me nuts cause the truck is so quiet except for this tick over bumps. ME Like Quiet. But I'm getting a flowmaster setup so that will go away soon.......
'04 Smoke XE 4X2
List of Modifications:
Performance : Volant CAI, Banks Cat-Back SS Exhaust, Helper Springs
Exterior
: Factory bedliner/mud flaps, Wade in-channels, Smartpark 2000 rear sonar,
Extang tonneau cover, Armada Air Dam,
Upgrade to SE 5 spoke rims, Nitto Terra Grappler 285/65/18's
Interior
: Weathertech Floor Mats
steveg warwick is offline   Reply With Quote
Old 02-03-2005, 04:28 PM   #8 (permalink)
BUGGER31's Avatar
Same sound in my 05. But I'm getting it from both sides. It started around 400 miles and I have 1600 now. Please post a solution if one is found. I will probably just let the dealer know at the first oil change. I just turn the tunes up and hit the gas and I don't hear it that much. I dooooo love this truck!
08' TITAN 4WD SE CC SWB(RED BRAWN)
Rockford package w/captains
Big tow package
Utility bed package
07' Volkswagen Rabbit
72' Super Beetle Karman Convertible
BUGGER31 is offline   Reply With Quote
Old 02-03-2005, 04:40 PM   #9 (permalink)
casique's Avatar
Same here on the driver's side...
2004 Radiant Silver Titan CC LE 4X4, DVD/NAV, big tow, no-offroad, Volant, tinted windows, utili-bed extender, Retrax Bed Cover, Zoomer Exhaust, Westin Bull Bar w/PIAA driving lights, Silverstars hi/low/fog, bug guard, Nissan Aluminum Diff Cover, smoke chrome grill cover and sun roof visor.
casique is offline   Reply With Quote
Old 02-03-2005, 04:46 PM   #10 (permalink)
TriKKy's Avatar
Add me to the list. I also noticed that if I crack my window a the tiniest bit...to just let some air in, the window flops a lot and makes a racket. I have bigger fish to fry.
1.
Old 02-03-2005, 05:02 PM   #11 (permalink)
Funny, I have the exact same ticking sound, same exact symptoms. It has nothing to do with the seatbelt because I always wear my seatbelt and it only happens while the truck is driving down the road, and not constantly either (comes and goes). I suspect its some plastic part rubbing against the door metal. I can stop it by pressing against the panel, also.
jdmartin is offline   Reply With Quote
Old 02-03-2005, 05:54 PM   #12 (permalink)
ctuck13's Avatar
I had the same ticking sound in my '04 SE KC and I also have it in my new '05 LE CC. I haven't worked on it in my '05 yet due to the fact that I have only had the truck a few days and it hasn't warmed up yet or stopped raining.
I got so annoyed with it in my '04 I finally just took the door apart. I stopped it, but I am not sure exactly what fixed it. but here is what I did:
1) slightly lubed the rubber channel with silicone where the window moves.
2) Removed the Plastic sheet from inside the door after removing the door panel and at the bottom where the opening is, the window regulator cable was flopping around and was tapping the metal with the window up fully, when you bump it down, it puts tension on this cable and stops it from flopping/tapping. You can't just tie these up because they have to be able to move freely, so I just padded the metal where it taps and also added padding to the cables where they rub each other. (sorry, no pictures)
3) Padded the area where the 2 cables go thru the door to the panel for the lock and the door handle, these where also tapping.
4) Padded some of the contact areas the door panel and the metal door near the top of the door, mainly near the back of the door.
5) Rolled the window down, pulled the rubber channel down a little, and at the top-rear area I added tape to take up space between the metal and rubber and made the rubber channel be a tighter fit on the steel.
6) adjusted & greased the door latches
And then I put it all back together.
I'm not sure if one of these fixed it or I just happend to get lucky in the process.
Hope this helps
TITAN #2 - Deepwater CC LE 4X2
Born on 10/2004 - Adopted on 1/31/05
TITAN #1 - Red Brawn KC SE 4X2 with RF
Born on 12/03 - Adopted on 12/27/2003
Traded for Titan #1 for #2 on 1/31/05
ctuck13 is offline   Reply With Quote
Old 02-03-2005, 09:12 PM   #13 (permalink)
Send a message via AIM to nursecrickett Send a message via Yahoo to nursecrickett
Had this noise in the 04....thought I got rid of it by getting an 05, but no such luck....
same thing....its a tiny annoying noise....goes away with my elbow, but not comfortable to do that coz its kind of behind me on the door.
Let me know what the heck it is....I'm going to ask the dealer when I take it in also...we'll see!
Crickett
nursecrickett is offline   Reply With Quote
Old 02-04-2005, 04:51 AM   #14 (permalink)
I have the noise on both sides and it is very annoying. I hate to have to crank up the radio because I like to just listen the the Titan's motor. I've asked the dealer to fix it a few times and they keep saying they can't find the problem. One time they even said that it is probably just caused by the brake judder (which, by the way, they can't seem to fix either!). I know it sounds like a petty little complaint but it's just so damn annoying!
Old 02-04-2005, 08:53 AM   #15 (permalink)
Same problem here. Faint ticking. I had the door apart once, and think I found it. The felt tape they use on the panels, near the top where it's ribbed. It spans across the ribs, and it crinkles if you move it. I tried putting some foam around the area to put pressure against it, but that didn't fix it. I bought some replacement felt, so I'm gonna try again. This time I'll remove their crinkly felt tape and do my own probably on the door side, not the panel.
It's a faint tick, and only on rougher roads, but it is annoying. I can't hear it when the windows down, but I was thinking that's because the wind noise is louder, and against the same ear. I didn't think about it being a loose window, I'll check that as well.
05' CrewCab Smoke -- All Stock (for now)
04' Ducati Multistrada
03' Honda CBR 954
02' Honda VTX 1800c
JohnC is offline   Reply With Quote
