Its not real hard to test for the short, unplug the fuse and put a continuity between the side of the fuse that goes to the outlet and ground. If you get tone then you have a short on that side. You likely dont have a short though as it would blow as soon as you change the fuse without anything in. So you could measure resistance between those points and see if you get anything other then infinite. If you actually get a lower reading then infinite, you have a connection thats draining current but not an acutal short. It could be that when you connect anything else you go over the fuse's 15 amp threshhold. If it were one socket, I would say that it was probably bad, but two is unlikely.
You did not hardwire anything into the wires that supply the outlet like a mp3 player or satalite radio did you?
