From what I've seen on the big 3, our type of intake is not that different, a fairly common way of routing the intake. My '95 Chevy 1500 picked up its air from the right fender in the same manner as our truck. I don't think it's a design flaw at all, manufacturers don't design or plan on owner's getting into water that deep. Keep in mind that you have other "weak links" to deal with besides the intake. Your axle tubes are not 100% water proof, you have numerous vent lines that would allow water to enter, you have electronics that aren't sealed, accessory belts easily slip, starter motors, bell housing, transfer case, transmission, etc. If you do some research into serious off roading, you'll see that truly water proofing a vehicle is near impossible. For example, Jeeps with snorkles still can't wade up to the hood without further modifications. Even then, it is highly recommended that you empty both differentials after fording deep water. Not saying that modding the intake wouldn't be a good precaution, I just don't want people to get the idea that all they have to worry about is sucking water into the engine. Too many times people submerge their vehicles and don't do any preventive maintenance afterwards and end up with ruined powertrains.
-Counsel Yourself
