Old 02-08-2005, 12:48 PM   #1 (permalink)
Update on Door Handles
Being its cold up here in Minnesota again my door handles got stuck, drivers door would not close and passenger door would not open. Called the dealership and to my surprise he was just going to call me because I had the problem during the last cold snap. They told me they had some Nissan engineers coming tomorrow and want me to bring the truck in today. They will be washing the truck today and leaving out tonight then the engineers will be looking at it in the morn. Ill let you know what happens as soon as I can.
JesseG is offline   Reply With Quote
Old 02-08-2005, 01:30 PM   #2 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
I hope they fix the problem with the door handles.
good luck
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 02-08-2005, 08:03 PM   #3 (permalink)
nmanley's Avatar
My rear doorhandle stuck open in freezing conditions twice. I pulled the panel and wiggled the cable and it came unstuck. I think if a cable luber is used and some synthetic lube squirted in the cables would solve the problem. Cables are lubed regularly on offroad motorcycles.
Nolan
2004 4x2 CC LE
Black Low Profile Bed tool box, Homemade bed cover, Delphi XM Roady2, Airbox mod w/Fram Air Hog filter, Banks Monster Exhaust installed, Mobile 1 Oil and filter, 85-145 Royal Purple Synthetic Diff fluid, Garmin Zumo 550 GPS, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring Like llajumpvid did his except using two 7" monitors for front and back coverage.
nmanley is offline   Reply With Quote
Old 02-09-2005, 03:16 PM   #4 (permalink)
Update 2
The dealer called this afternoon and said the engineers have been working on the doors, guess they are replacing some parts but won’t know exactly what they replace till tomorrow. They also found my rear transfer case seal leaking again. I had that replaced about a month ago. They said they think its from the drive shaft so there replacing that also ( Drive Shaft and Seal). I’ll try to get a parts list for the doors when they are done.
Old 02-09-2005, 05:17 PM   #5 (permalink)
HEMI-SMOKER's Avatar
[quote=JesseG They also found my rear transfer case seal leaking again. I had that replaced about a month ago. They said they think its from the drive shaft so there replacing that also ( Drive Shaft and Seal). I’ll try to get a parts list for the doors when they are done.[/QUOTE]
Not trying to change the subject but I'm curious about your tranny leak. I just went to pick up truck today with a tranny leak and got down the road and it leaked again. They thought it was the drive shaft seal but then said after it leaked again that they didnt know. They called me 5 hours later and said that it was some bolt leaking and that they had fixed it. I havent picked it up yet. Your the only other person ive seen with this problem. What did they replace on your truck? Mine is a 4x4 also. Did they replace the actual transfer case seal? I know they havent had time to do this on mine. Im concerned they just put silicon around the bolt to stop the leak. Sorry again for the subject change. Thanks in advance for the info!
04 DEEP WATER BLUE/ BORN ON 9-04/SE/KC/4X4 OFF-ROAD/ BIG TOW/UTILITY/SE POPULAR WITH BENCH
TINTED WINDOWS /MRGRILLE BRUSHED INSERTS/
2.50" CAT BACK CUSTOM SYSTEM WITH MELLOTONE XPS AND 3.50" SLASH TIPS,
HEMI-SMOKER is offline   Reply With Quote
Old 02-09-2005, 07:53 PM   #6 (permalink)
They replaced the seal on the end of the transfer case were the drive shaft inputs to the case.
Old 02-11-2005, 11:24 AM   #7 (permalink)
Picked up the truck today but did not get a chance to talk to the engineer. They did replace both door lock actuators. Almost 40 deg. Today so I’ll have to wait till we get another cold snap to find out if it fixed the problem. They are aware of the problem because they had the parts with them and also replaced the actuators on a couple of trucks on the dealer lot. They also replaced the rear transfer case seal and drive shaft. I’ll check that again after I put on a few miles.
Old 02-12-2005, 01:53 AM   #8 (permalink)
I have two friends that are nissan mechanics and they had the same problem here in Maine. They showed me the door handle assemblies where they were soaked with water around some foam around the cables. There is water getting in the door panels and freezing the foam around the cable causing it to stick. Hope this helps.
Pman is offline   Reply With Quote
