I hear what your saying and on some vehicles Ive owned I didnt even turn the rotors , just replace pads and keep going as long as everything is straight (although I will hit the rotor with a light scuffing pad when doing pads) but my towing rigs have been a bit different in terms of brake life.
Based on experience with my 93 lightning, a 96 chevy 1500, and my work Suburban (2001 5.3 litre)-
(I preface this by saying the largest variable in brake life depends on what you do with your rig)
For me-
Factory fronts last in total about 60-80K with a turn and new pads at about 35-40 and then it depends as they are more prone to warping after turning. They may get replaced they may get turned again and go till 110-120 Its happened once with my 93 lightning. The surburban loves pads and rotors, the 1500 did ok.
Backs can last 100K before you turn, and I dont usually turn back rotors, but just replace them.
I tow fairly often and heavy, and when I do I do it through the southern cal/Arizona dessert up and down really big hills and sustaining fairly high speeds over long periods of time. The warrior loaded up with 2x banshees, a dirt bike /wood/propane/food/ beer, and 25 gallons of gas and 40 something of water is around 7-8K.
My boat is about 5500 loaded up with trailer and all, and I occasionally drag 27-30ft boats around that push teh 9500+ pound limit pretty hard with 4-5 200 lb guys and a bed full of gear.
The aftermarket brakes are fairly cheap iunsurance for me. I also keep things I like a long time (95 Maxima) and mod them sometimes heavily over the course of ownership so I'm a long term guy in terms of keeping and maintaining stuff.
As I said in another post - dragging 5K+ of stuff down from 70+ on 8 mile long 4% downhill decreasing radius turn is hard on brakes and nerves.
What are you riding? The pict looks like maybe an st100?
Davegvg
04 Titan CC le 4X4 big tow
95 Maxima Stillen blower/brakes
21ft Laveycraft sebring tunnel (406 small block 100+ mph)
2 Yamaha banshee stage3/4
Cr-500
24ft weekend warrior
2 segway human transporter
1 96 BMW Z3 (wife car hate it)
Kalamazoo BB4 dual fuel SS grill
