Old 03-21-2005, 06:57 PM   #1 (permalink)
Pros/Cons of Big Tow
Hello, I am seriously considering making the move to a Titan after a long history of driving GMC trucks. I was hoping to get some feedback regarding the Big Tow option. I definitely need a 4X4 and plan on the Off-Road package, but am unsure about the B.T. At this point, I rarely do any heavy towing (typically just a utility trailer with 4-wheeler at this point). Is there much difference in fuel efficiency? Does anyone wish they had or had not gotten the B.T. package?- that kind of thing. Thanks for any feedback!
Bull is offline   Reply With Quote
Old 03-21-2005, 07:02 PM   #2 (permalink)
Clint's Avatar
The offroad version has the same rear gears as the big tow. So from that standpoint it's no different in mileage. As far as towing capacity you never be sorry if you buy the big tow. You'll also get the larger mirrors, trans temp gauge etc. All in all it's a lot for the extra $400.
Clint
You have two choices in life:
Old 03-21-2005, 07:08 PM   #3 (permalink)
TYTAIN's Avatar
Bull, depending on some differnet options you may have to get big tow. You may want to go to the Nissan's web site and spec your truck out to see what's avalible(SP) that way you know for sure what your up against. I have it on my 04 CC LE with OFFROAD, never hurts on resale if you ask me. Good luck!
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's
PRG Shackles
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 03-21-2005, 07:17 PM   #4 (permalink)
Thanks, that has already helped a ton. I've built some different models on the website but completely missed the fact that the offroad has the lower gear ratio.
Old 03-21-2005, 07:17 PM   #5 (permalink)
HudsonValleyTitan's Avatar
I have to agree with the others here. Same gearing as the OR equiped truck so mileage isn't an issue. The hitch, wiring and controller wiring are there for when you want to move up to a larger trailer becuase now all your friends want you to tow their ATV or, like I did...lol...ended buying a camper trailer!
I'd have to say go for extra few $$$ and be comfortable knowing you CAN tow up to 9500 LBS rather than 7500 w/o the package. Good luck!
Old 03-21-2005, 07:32 PM   #6 (permalink)
mtbendo's Avatar
Pros - the big mirrors, you can see everything
Cons - the big mirrors, you hit almost everything
Serious, I have both options (Big Tow and Offroad). I've never towed anything big in the past but it's nice to know that you won't regret it later should you decide to do so. The trans temp gauge is a plus and so are the bigger mirrors on the freeway. The biggest plus for me at the time was that the early 04s had VDC as an option with the Big Tow. Since my wife would occasionally drive it I thought it was worth it.
04 Galaxy Black Crewcab LE/Big Tow/Off Road/Nav/DVD
Hood Protector/Gibson SS Extreme Duals/Leer XQ Shell/AEM Brute Force
KC Backup Lights/Stainless Steel Grille/Chrome Tailgate Trim/PRG Mini Lift
mtbendo is offline   Reply With Quote
Old 03-21-2005, 08:57 PM   #7 (permalink)
Very happy with BT
Pro's - Transmission temp guage! This is really nice to have when towing in the mountains. The big mirrors are great. Plus it comes with a heavy duty battery.
Con's - Gas mileage. I'm not sure how much difference there is compared to the no tow models. I think there was a survey on this a while back.
2004 SE King Cab 4X4 Deepwater
Big Tow
Fog
ARE LSII Tonneau
265 70 R18 Bridgestone Dueler Revos
MilesTeg is offline   Reply With Quote
Old 03-22-2005, 06:32 AM   #8 (permalink)
Quad T's Avatar
If you are already spending the money for the Off-Road Pkg you might as well spend the $400 to get the BT Pkg. As others have mentioned you will already be on the wider OR tires and have the lower final gear ratio, so the only diffwerence in mileage would be as it relates to the extra drag on the big tow mirrors and I suspect you would never see that in gas mileage.
Big Tow, a lot of stuff for $400 or less...
Big Tow Package (SE and LE Only)
• Class IV receiver hitch
• Additional 7-pin wiring harness plug
• Trailer brake controller pre-wiring under instrument panel
• Heavy-duty battery (710 CCA)
• Lower final gear ratio (3.36:1); similar to 4.10:1 on a 4-speed automatic
• Extendable tow mirrors
• Transmission temperature gauge
• Increased tow capacity
SE: Requires Trac Package (4x2 only). In addition, SE Rockford Fosgate Package or SE Popular Package is required.
Quad T
TITAN TOWS TRACK TOY
The Big Red Beast - AKA - Project Titan Nissan Sport Magazine
'05 Titan SE 4x4 KC, Red Alert with Graphite/Titanium
Popular Package, Utility Package, Big Tow & 17" Off Road Wheels, and more to come...
Quad T is offline   Reply With Quote
Old 03-22-2005, 07:48 AM   #9 (permalink)
TROGDOR's Avatar
Send a message via AIM to TROGDOR
The mirrors after market are 150 a piece - so that's 300 bucks right there. Honestly, having not driven a full size before (coming from a Maxima), I don't know how I'd live without the mirrors. The wide-angle bottom mirror makes driving on highways and back parking a breeze ...
2004 Black KC 2wd OR BT UT RF
SHIFT_burninator
PRG "Mini Lift"
TROGDOR is offline   Reply With Quote
Old 03-22-2005, 08:00 AM   #10 (permalink)
ptgarcia's Avatar
I wouldn't buy a truck this size without the tow package. Like everyone has said the cost is minimal and there are no "cons" (in my opinion).
Pauly
Old 03-22-2005, 08:12 AM   #11 (permalink)
aux trans cooler
I think an additional aux trans cooler is part of the big tow as well.
kevstitan is offline   Reply With Quote
Old 03-22-2005, 08:17 AM   #12 (permalink)
QWIKWHIP's Avatar
That is my only regret with my truck is not getting the tow package. It hasn't been a problem for me but it will limit my plans if I want a larger camper in the future. My reason for not getting it was that the mirrors would not fit in my garage without folding them in everytime. I guess I could have learned to live with that. Oh well. In a few years my next one will have the tow package.
Old 03-22-2005, 08:17 AM   #13 (permalink)
QWIKWHIP's Avatar
They all have teh cooler, it's just the gauge that comes with the TP.
Old 03-22-2005, 10:44 AM   #14 (permalink)
Justintoxicated's Avatar
I got the big tow package with my OR equipped also. My Dad went out and bought a pimped out 21 foot toy hauler and gave me one of the keys so it ended up being a very good investment I get about 16 MPG average on the street + freeway
Old 03-22-2005, 10:51 AM   #15 (permalink)
ptgarcia's Avatar
Justintoxicated,
I'm looking to buy the same thing. How does it tow?
Pauly
