Old 03-24-2005, 08:39 AM   #1 (permalink)
Arrow HELP, Cannot install PRG Leveling kit
I am trying to install my PRG levling kit and in step 2 it tells you to:
"Step 2. Locate the nut that retains the upper ball-joint to the spindle. Remove and discard thecotter pin. New cotter pins are provided with your kit. Do NOT reuse the old cotter pins! Next, remove the nut that retains the upper ball-joint to the spindle. After the nut has been removed, lightly tap the side of the spindle with a hammer until the upper ball-joint pops
free from the spindle.
Do not use a ball-joint splitter (aka pickle fork) as you can damage the rubber boot that retains grease for the ball-joint. (Figure 2.)
Figure 1. Figure 2.
I cannot get the spindle to seperate from the upper ball joint!! ANY ideas???
Methu969 is offline   Reply With Quote
Old 03-24-2005, 08:45 AM   #2 (permalink)
QWIKWHIP's Avatar
You just have to keep hitting it. It will eventually pop out. There isn't really any special trick to it.
Old 03-24-2005, 08:46 AM   #3 (permalink)
Greg installed mine himself, he stated to me that he had to re-write the directions because people are not hitting the spindle hard enough. You need to hit it hard enough to pop it out. Dont be scared to wack it. When he did mine he hit it hard and on the third hit it popped out. Just do not use a sledge hammer. If you still cant just call Greg, I'm sure he will be happy to answer your questions.
2004 Galaxy XE CC 4x4(DOB 8/04)
* Power package * Bed extender
* Off road package * Rear elocker
* XE Preferred Package
MODS
* DVD/TV tunner 7" Headrest Monitors
* Stock airbox mod
* SE power mirrors upgrade
* XM Radio "Skyfi2"
* PRG leveling kit
* 2005 Aluminum Diff Cover upgrade
sigmapititan is offline   Reply With Quote
Old 03-24-2005, 08:51 AM   #4 (permalink)
I have been beating on it for an hour and am getting pissed. I am trying some WD40 to try to losen it. I do not want to break the spindle.
Old 03-24-2005, 08:55 AM   #5 (permalink)
GOT IT!!!!!!!! ARRRRRRRRGGGGGGGGGG
Thanks, the instructions did say TAP and you have to nail it pretty good. THANKS!!
Old 03-24-2005, 08:58 AM   #6 (permalink)
Carful with the brake line and abs line's suspend the knuckle with a strap DO NOT LET THEM STRETCH..
05 Titan Smoke CC SE
00 RM 250-4 sale
02 CBR 954 RR
74 Harley Super glide
90 CB-1 race prepped (classic) highly modified
06 Gixxer 1k (coming soon)
My drinking friends have a racing problem!
It's ALL about the RIDE!
MOTO-MAX-TITAN is offline   Reply With Quote
Old 03-24-2005, 11:27 AM   #7 (permalink)
VShortt's Avatar
What you just said is correct. Greg has even said that he is aware that it must be struck pretty hard. He probably just didn't want to include "beat the hell out of it" in the instructions.
New List of Mods Coming soon
Old 03-24-2005, 04:03 PM   #8 (permalink)
HavockWK's Avatar
Listen to Moto-Max and VShortt... They are wise in the ways of the PRG installation...
When we installed mine, we used a smal sledge, like a 3 pounder of so, and then gave 3 pounds to the part that curves away from the ball joint itself so that we were not actually pounding the joint directly.
